Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
My refrigerator and freezer are not as cold as they should be. freezer is at 13 degrees when it should be at 0, and the refrigerator is at 43 degrees when it should be around 30. please help.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
I opened up my frig and the temp said the freezer was -13 and the frig is at 55 degrees. When I presed it down it changed to 2 in the freezer and 32 in the frig part. Put after about 3 to 4 seconds it...
the damper vent door between the freezer and fridge compartments is frozen shut or if motor operated it broken or the motor is bad or power to motor is missing to open and close this door to let cold air into fridge from freezer also there is an evaporator fan near here make sure it is operating or cold air wont be moved
May 22, 2011 | Refrigerators
Freezer is -13 &frig is 56 degrees
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 16, 2011 | GE Monogram ZICS360NR Bottom Freezer...
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Sep 10, 2009 | Westinghouse Refrigerators
Freezer won't get below 13 degrees
Make sure the evaporator coils behind the rear cover inside the freezer are not iced up too much. This would indicate a defrost problem and will get worse.
If the compressor is still cycling off and on the cold control could be at fault.
Aug 20, 2009 | Freezers
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
