Question about Moen & One Handle Tub & Shower Faucet
No hot water flow again from upstairs tub faucet, replaced cartridge last year in single handle moen legend faucet for same problem, now this is the second time in one year? Is this common?
  • 29 Answers
Could it be a problem or a blockage in the mixing valve?
Posted on Nov 09, 2010
Get hot water only....when rotated to cold get nothing....replaced cartridge but still the same.....shower has been unused since house was built
If you don't have easy access to hot and cold line, where you can disconnect and check for flow to faucet, You can try turning off incoming water supply, remove cartridge, and shut off hot outgoing at water heater, then slowly open incoming (cold) water supply only and see if cold flows from faucet with cartridge removed. At least that will confirm flow faucet, then go from there.
Sep 19, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I replace the O-rings and cartridge on a legend
check the diverter sleeve/collar it may be getting in the way ,and water push's it out of the way.
Mar 02, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I get hot water but no cold water from my moen one hand tub fixture.
pretty sure that model has shut-off's/stop's.they are on either side of the center of faucet,they take a slotted screw-driver.check that,and the balancing spool could be clogged,if the stop's are open check the cartridge real good,as well as the faucet body for any debris. if you end up pulling the cartridge flush out the valve body to prove flow from both hot,and cold.
Feb 18, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Tub will not turn off
need a new cartridge if you call moen they will send you the part for free
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Moen & One Handle Tub & Shower Faucet  Logo
169 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
