Question about Pioneer Car Audio & Video
Which wire in a 2000 hyundai accent hatchback is the constant 12v for the radio?
  • 139 Answers
Constant 12V = Orange / Black
Ignition 12V = Gray / White
Posted on Nov 09, 2010
Wiring mex bt31pw cd player to 2003 hyundai accent with no wiring adapter. Need to know what color wire go to what on the vehicle
2003 Hyundai Accent Car Radio Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Orange/Black
Car Radio Switched 12v+ Wire: Pink
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Black
Left Front Speaker Positive Wire (+): Red
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Brown
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Black/White
May 01, 2017 | Hyundai Cars & Trucks
I need a radio wiring diagram for a Hyundai Accent 11/2000.
Radio 12v orange/black + radio
Radio Ground black - radio
Radio Ignition blue/black + radio
Radio Illumination green/orange + radio
Factory Amp Turn-on
Power Antenna pink + radio
LF Speaker +/- red - blue radio
RF Speaker +/- white - brown radio
LR Speaker +/- green - orange radio
RR Speaker +/- orange - blue radio
Feb 27, 2011 | 2000 Hyundai Accent
How do you remove the stock radio from a 2007 accent hatchback
First, you have to remove the bezel that surrounds the radio. You have to find something thin and sturdy to slide in behind the bezel to carefully pry it away from the dash assembly. Something along the lines of a plastic spackling knife will prevent scratching the dash. There are no screws, only clips holding that bezel in place.
Once you remove the bezel, you will see four screws holding the stock radio in place. Remove those, then slide the radio out.
You will need to unplug the wiring and antenna from the rear of the unit for complete removal.
Apr 22, 2010 | 2007 Hyundai Accent GS Hatchback
Timing 2000 hyundai accent,tried puttin new belt on,lined up marks ,then noticed second timin g mark on cam WTF
have diagram can email you need email address to send to, also is it a L Hatchback, GS Hatchback, GL Sedan
Feb 09, 2010 | 2000 Hyundai Accent
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
2000 hyundai accent passenger door willnot
the door 'lock/unlock' actuator is siezed up (corroded).... replace it (or have it replaced).
Oct 03, 2009 | 2000 Hyundai Accent
I have a 2000 accent.I'm trying to self install my old eclipse deck but need a diagram for the accent wire set up.
Black - Neg. (-) earth, Orange/Black stripe - Constant 12V, Blue/Black stripe - ACC 12V, Green/Orange stripe - Pos.(+) Dimmer, Green/Black stripe - Neg. (-) Dimmer.
There are two Orange and two Blue wires, you will need to work out which is which, it's not hard.
Front Right - (+) Brown,(-) White;
Front Left - (+) Red, (-) Blue;
Rear Right - (+) Blue, (-) Orange;
Rear Left - (+) Green, (-) Orange.
Sep 01, 2009 | 2000 Hyundai Accent
2004 hyundai accent audio fuse blowing
Either the radio itself has developed an internal short, or there is a short along the wiring from the fuse box to the radio. It is one or the other. If the fuse blows with the radio turned off, then the problem is a short in the wiring from the fuse box to the radio. In that case, its time to try to crawl up under your car's dash and hopefully find where the wiring has rubbed against a piece of metal and shorted out.
Mar 30, 2009 | 2000 Hyundai Accent
Radio wires cut in my car need code and or diagram for jvc-r300
this is easy to do and you musnt be scared.first find 12v permanent ,then 12v switchable,ground ,ignore electric aerial which is normally blue or yellow use a piece of twin flex connected to battery and flash speakers so you know which is where,good clue is speakers have same coloured wires but one has a black or white flash through it .And away you go music
Jan 27, 2009 | 2003 Hyundai Accent
Car Audio & Video Logo
54 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
