Question about Husqvarna 16" 457cc Prosumer Chain Saw 445
New saw idles great, but when i give it gas it stalls out
  • 7,733 Answers
MAKE SURE WHEN YOU START A JOB YOU NEED TO PULL THE UPPER BAR TOWARDS YOU IN ORDER TO RELEASE THE CARB CHOKE SENSOR.WHEN YOU DO A COLD START THE UPPER BAR GO TO THE FRONT POSITION TO WARM IT UP OR STOP SAW JOB.
Posted on Nov 09, 2010
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: saw stalls on giving it gas but idles ok
Hi ifwas...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of most chainsaws.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the chainsaw is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Sep 06, 2011
  • 211 Answers
SOURCE: husqvarna chain saw stalls
hi charlier 421
I think the small holes from the Venturi wall of the carb are clogged.To clean them you need carb disassembly.Near the needle there is a tehnological cover,under the diafragm(fuel pump).Taking off it you will see some small holes maiking conection with Venturi wall.Used ompresed air to clean them.
best wishes savumihai71
Posted on Dec 01, 2008
  • 173 Answers
SOURCE: hi , my saw starts
It sounds like you are going to have to rebuild the carb or replace with new one.
Posted on Nov 24, 2010
Testimonial: "i decided to take apart the carb i dint have a carb kit accessible so did a good cleaning and put it back together .. i t now runs great .. thanks for putting me in the right direction ... cheers."
Runs idle but stalls when give gas
Yes. Sometimes the internal screen deteriorates and clogs the fuel pump. You might want to replace the fuel filter and blow through it to see if it was clogged too.
Feb 27, 2014 | Ford Crown Victoria Cars & Trucks
'97 crown vic cranks but stalls immediately
Idle air control valve. And/or gunked up throttle body, pcv port at throttle where mating to intake manifold.
Jul 08, 2017 | 1997 Ford Crown Victoria
Brand new weedwacker keeps stalling when i give it gas
try giveing it about a quarter choke untill it warms up.
Jun 26, 2012 | Husqvarna 128 LD Weedeater
Engine stalling when i step on gas petal. Idles great, just acts like its gonna stall when i give it more gas????? cuts out around 2000rpm???
check the distributor cap,, clean any corrosion that's in the cap,, clean off the rotor tip,, you may need a new set of plugs, and or wires , if these don't fix the issue,, get some carb cleaner and spray it into the carb or throttle body of your motor, and check the idle control sensor in your vehicle
Sep 23, 2011 | 1992 Toyota Celica
I have a newer model Husquarna chainsaw. When I give it extra gas it stalls in the sweet spot. If I give it max gas it cuts off. When I try to saw it wants to cut off also. I changed the gas and tried that...
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn. If you have to change the high rpm jet a lot you might have to go back and readjust the low rpm jet again and set the idle speed. Never idle it high enough that the chain turns while at idle.
We used to have to do this a lot in timber business. You go up on the mountain to cut logs and the altitude has high enough that you had to adjust carburetor and then do it again when you got back to the sawmill.
Jun 04, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Engine stalls
Sound like the clutch is not disengging. The springs in it are likely week. Take note as to weather the chain stops when it is idleing. If it seem to idle at a reasonable speed and the chain does not stop turning, the clutch is most likely the problem. This problem can be caused by trying to work the saw without the throttle wide open. When the clutch slips it creates heat wich will over heat, and weeken the springs used to disengage the clutch. It is also possible that it was defective when new.
Jan 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 3700 will not keep running
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 16" 457cc Prosumer Chain Saw  445 Logo
222 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
