Thermostat connections neede - Heating & Cooling
  • 43,501 Answers
Here is a list of each common terminal and what their commonly used for. Also listed is what colors are commonly used. NEVER ASSUME these are what you have. Verify all your wires by following each to each piece of equipment. This will help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101
Posted on Nov 09, 2010
How to change oven sensor
How do you know it is a sensor problem? If you know. usually there will be instructions with thepart. http://www.amazon.com/12001676-Admiral-Aftermarket-Terminal-Receptacle/dp/B00IFA6TZW This part is the connection between the burner and power to the burner by way of the oven thermostat. It is not a sensor connected to the thermostat. The thermostat sensor is the long tube usually on the side of the oven. it has a small tube that connects to the oven thermostat. So if you have determined that the issue is the sensor or thermostat you will need a complete thermostat and the sensor I described. Some appliance parts dealers will help you if you have problems. I assume your existing part has burned and you get no voltage at the outlet? Usually the connection you cite is behind the plate holding the burner to the back of the oven. So you will need to remove the burner which will expose the connection the rest is just careful connection of wires usually by screws for the wires.
Feb 13, 2015 | Admiral Stove Oven Range Burner Receptacle...
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
Need to know wiring diagram for IMIT TR2 9325 thermostat
The three connections are labled (C),(1),and (2). (C) is common (useually the white wire). (1) is hot power into the thermostat (black wire). (2) is ran to your heater. So when the thermostat is turned on it will connect (1) and (2) until it reaches tempature. Hope this helps.
Nov 20, 2011 | Cars & Trucks
My old thermostat had 4 wires connected to it, I have 5 wires white black ,blue,yellow and red. the wasn't connected to the old thermostat.Do i need to connect the red one to the new thermostat because...
locate the wires at the unit and hook them up in the same way . If it was not hooked up before you most likely don't need to hook it up now.. but check the unit where the wires connect to it.. let me know Have fun
Jul 24, 2011 | Heating & Cooling
I have two 208/240 volt electronic heat relays r841c1169 and I need to contol them from one thermostat
try to connect relays only one line connected series connection with your thermostat so that if the thermostat cut off relays controlled
Feb 18, 2011 | Heating & Cooling
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
How do you install a 2 wire heat only honeywell thermostat?
TURN THE POWER OFF. You need to be sure that the thermostat is made for the control voltage of your furnace. If the new thermostat has mercury contacts it has to be level to be accurate. One wire would be connected to the R terminal of the thermostat sub base and the other wire would be connected to the W terminal on the thermostat sub base. Seal up the hole in the wall where the wires pull through so cold air does not effect the thermostat. If the thermostat has an adjustable heat anticipator you will need to check the amp draw through the thermostat to set the anticipator properly. If you do not have an amp meter I would start out at a .4 amp setting and see how the thermostat cycles.
Nov 24, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I have a honeywell thermostat model # th5220d1003-0636 & need to know what connections to make for gas forced air heat.
This is a Focus Pro 2 heat,2 cool thermostat. If you are connecting this to a single stage(1 heat) residential furnace then your connections are: At the thermostat the R and Rc therminals are internally connected so you can connect your R terminal wire from the furnace to the R terminal at the thermostat(this is your 24 volt supply for both heating and cooling. The W or W1 wire (heating) from your furnace you connect to the W1 terminal at the thermostat. The W2 wire from your furnace(if your furnace is a 2 stage furnace) you connect to the W2 terminal at the thermostat. The G wire from your furnace(indoor fan) you connect to the G terminal at the thermostat. The Y1 wire(cooling) from your furnace you connect to the Y1 terminal at the thermostat. The C wire(common or neutral) from the furnace you connect to the C terminal at the thermostat.
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
How do i change a thermostat??
buy the correct thermostat and thermostat gasket for your car, then locate the upper radiator hose. Where the upper hose connects to the engine there should be a two bolt hose connection/ thermostat housing ( could be 3 or 4 bolt, but most are 2) these bolts should be removed and then gently lift the hose and hose connection/thermostat housing exposing the old thermostat. note the position then replace the new thermostat just as the old was installed.
Oct 27, 2009 | 1996 Ford Contour
Kenmore Electric Dryer Model # 110.62622101
Wedge, one red wire to the right terminal of the heating element. The safety thermostat should of had a piggy back that fits over the left side terminal of the element and connected to one side of the safety thermostat. Other red to other side of safety thermostat, Orange from the timer (smaller connector) to the respective connection on jumper. Catriver.
Dec 01, 2007 | Kenmore 72982 Gas Dryer
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
