Question about Mitsubishi VS-5043 50" Rear Projection Television
TV shuts off immidiatly when you try turn it it on
I had a Sony that did the same thing. It ended up being a blown fuse on the board. Check to see if any of the fuses are blown. They're cheap and easy to replace usually. Make sure you use the same amperage fuse when replacing.
Posted on Dec 07, 2010
I switch off the freezer to defrost the ice build up on the top shelve as I tried to switch it on the compressor come on and immidiatly stops again.
unplug or power off to unit and leave doors open for at least 12 hours. power back on and it should reset.
May 05, 2015 | Refrigerators
Hi ive got a Sony VPCCW15FG .PCG-61111W LAPTOP if i switch it on the lights come on then immidiatly goes away and does not switch on .What can be the problem ,does it need to be reset or something please...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
If it was OK, then plug-in the battery and try to start your laptop.
If it was OK, Congratulations.
If not, so it's bad news, the battery is dead.
Please tell us your results
Good Luck
May 17, 2011 | Computers & Internet
My ht-z31 dvd surround sound turns on and immidiatly says protect and shuts down. what do i do?
the protect means a circuit overload check that you dont have any wires for your speakers touching or backwardly installed if those are all fine you may have blown a fuse inside the receiver.
May 07, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
My tv, and also my mother in law's, which were both bought at the same time 6 years ago, started turning off by themselves. They won't turn back on immidiatly but if I wait a few minutes They will come...
Hi drewpearce,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 20, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Trane XR80 blows cold air. Inducer motor comes on, glow bar glows for few seconds than goes out and inducer motor shuts off. Immidiatly after the main blower comes on and blows cold air. Will blow until...
I know that it's easy to spend someone elses money but in my experience when you get one actig that erratic it's usually the control board. I would check all the wiring including thermostat. You never know you might get lucky. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
I recently removed my battery to prevent a theft i replaced the battery now every time i place it in park, or nuetral, it stalls, although re starts immidiatly soon as i put in park and turn the key...
HI disconect battery cable and recconect start engine let it idle for 10 minuts do not touch gas peddle let it relearn idle strategy if this doesent help try cleaning throttle plate by using carb cleaner or the special cleaner whit engine of open throttle spray cleaner using a tooth brush scrub throttle plate till clean
Dec 01, 2009 | Dodge Ram 1500 Cars & Trucks
I've sony vaio vgn-cs110e purchased from US before 9 months, it works fine till today but today when i turn on the notebook it stats normally and also i can work normally on it but suddenly after 5 minutes...
You have to tell us the error message that it shows when it turns off. And if it is not showing any message and just die to black screen, then its a motherboard problem.
Sep 20, 2009 | Sony VAIO VGN-CS110E/W NoteBook
Car overheated sounds like it want to start but it wont
You could be in big trouble if the engine turns over slowly when trying to start when engine is cold (not warmed up). Check the charge in your battery and connections to make sure they are clean. If they are ok and it still turns over slowly and does not start you may have major engine repairs due.
May 30, 2009 | 1991 Toyota Camry
Lg kg110 unlock
You will need to take the phone and have it unlock or try mobile2mobile.net or unlockitnow.com
Sep 13, 2008 | LG KG800 Cellular Phone
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
