Question about Canon GL2 Mini DV Digital Camcorder
After a few minutes of recording a change tape message appears and tape becomes slack.
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 09, 2010
HI! I'VE JUSTED WENT THRU THE GR-D770U MANUAL BUT HAVEN'T FOUND ANYTHING REGARDING STEPPING OUT OF THE "UNIT IN SAFEGUARD MODE", EJECT AND REINSERT TAPE, THERE IS ALSO 03 NUMBAR IN THE SCREEN! THANKS
To reset the error message, unplug the video camera from its power source and remove the battery. Wait at least two minutes. Next take out the cassette. Wait a few more minutes and then reconnect the power source. Replace the battery and then the cassette. Turn on the camera and see if the error returns.
In some cases, the solution is to press and hold the play button while you turn on the video camera. This starts the camera in playback mode and avoids the error. Turn off the camera, then press Rec while turning on the unit. This starts the camera in the recording mode and also resets the machine.
If neither of the above solutions work, try using a different cassette tape. Sometimes, the tape will slip when the camera does a self-test and a new cassette might not have the slack issue. This can trigger the error. Otherwise, the GR-D770U needs service. I hope this helps.
Jul 02, 2018 | The Video Cameras
Will no longer record answers because "out of
Hi, I would suggest that you get another tape. Because after so many recordings the tape will become unreadable by the machine. Replace the tape.
Aug 18, 2011 | Panasonic Lands Phones
I own a Canon XL1 video camera, the problem is that Sometimes when I hit the record button the camera fails to record for up to a minute or so and then the picture breaks in. When this first happened a...
It seems your recording head is dirty, i would advise running a cleaning tape through it regularly or have the camera cleaned and checked at a Canon service.
Feb 28, 2011 | Cameras
"Remove the cassette"
I only got the problem when the tape was bad. Usually the ribbon got folded, or was very wrinkly looking. Eventually I found out the drive was bad, and had to have it replaced.
May 08, 2010 | Canon XL1S Mini DV Digital Camcorder
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Condensation operation posed
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Mar 02, 2008 | JVC GR-D30U Camcorder
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
