Question about Epson EX31 Projector
I have EPSON EX31. My projector does not project STRAIGHT IMAGE. The focus image on the wall is slightly tilt. It is slightly cross. Earllier it was working fine. Plz help
marsrover
  • 682 Answers
SOURCE: projector gives a red background
try video signal from video or from dvd if you get the same result you have problem inside the projector and need to be fix in workshop near you.
Posted on Apr 28, 2008
Basti
  • 1447 Answers
SOURCE: cut off part of projected image
Hi-
Try changing the cables and try setting the resolution to 800x600 on the computer.
hope this helps
Posted on Aug 25, 2008
  • 6 Answers
SOURCE: Wall paper is displayed however not the PPT or Icons
You need to configure your video card.
I'm assuming this is a laptop you are working with. Go into the video card properties, and make sure the VGA port that drives the projector is not set to extend your Windows desktop.
From your desktop, right-click and choose the "properties" option.
In the Display Properties window that comes up, select the far-right tab "Settings".
See the rectangles labelled 1 & 2? Click on the rectangle with the 2, and then look down near the bottom where you'll see a checkbox with "Extend my Windows desktop to this monitor."
Make sure this box is not checked (it most likely is right now, and that's the source of your problem).
Posted on Mar 31, 2009
projdoc
  • 2237 Answers
SOURCE: in focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Posted on Aug 18, 2009
SOURCE: One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Posted on Dec 10, 2009
I have 2 epson EX31 projectors in our sanctuary that run the same image from the MAC. (song lyrics, slides, etc) Recently I replaced a bulb in one...and since then...the "White" levels in the projecto
If uniformity of the images is important, I would reccommend replacing the second bulb on the other projector with the same bulb, from the same vendor as you did the first. It may be too difficult to match them up otherwise (assuming the first bulb you bought isn't defective).
I hope this helps,
--Robert
Oct 29, 2014 | Epson EX31 Projector
Cannot focus uniformly across the projected screen. This seems to be more than a focus problem in that some areas of the image seem blurry as opposed to out-of-focus. Also, in what may be a related...
try bringing the screen up as close as possible to the projector and still get a focused picture. check keystone here and also for image clarity. if you still have problems, check for dust or moisture etc in the optics. check the lamp for a clean front surface. clean the air filter also. Try a different image source for differences
May 20, 2011 | Eiki LC-XB25 Projector Multimedia...
Hello, How can I move the Lens of the S300 Dell. It projects under 30 degrees up. I need it to beam straight
try to adjust the tilting image knob.. if the projector is elevated on the front.. adjust the bottom side of the image shorter than the upper side..
May 12, 2011 | Dell S300 Short Throw Projector 2200 ANSI...
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
My projector has started projecting with a very dim image - very difficult to see even with room lights dimmed. It has been working weel with a great image until now - approx 1.5 years old used an average...
I've got the same problem. Just replaced the bulb but the image is no brighter. Our unit is two years old and operates about 6 hours a day. It is dimmer and more out of focus when run from a Windows computer.
Feb 04, 2011 | Epson PowerLite 410W LCD Projector
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
Projector proects tilted image
hi,
Relocate your projector parallel to floor and Restart and apply keystone
correction giving signal to projector.
Rave Services
Jan 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Epson EX31 Projector Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
