Question about Amana ARS266ZBS Side by Side Refrigerator
My amana Ars9169as is not freezing I just had to replace the overload and everything seems to be working
4 Suggested Answers
  • 50 Answers
SOURCE: Ice maker not working. refrigerator is freezing
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Posted on Aug 01, 2010
woodchuck789
  • 4070 Answers
SOURCE: Freezes even refrigerater side. Have
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is stopping when the compressor cuts off. . You may have to hold the door switch to see if it keeps running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages which move the flap.
Posted on Nov 01, 2010
imufo2
  • 3773 Answers
SOURCE: Amana side by side refridg/freezer.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 20, 2011
I have a amana refrigerator and its not working right I cleaned the condenser coils and checked everything now it doesnt seem to make ice
Is the freezer freezing the food rock solid? Most ice makers require the freezer to reach a certain temp before it will make ice. What is the model number of your unit?
Apr 06, 2013 | Refrigerators
Amana side by side refridg/freezer. Freezer not freezing, everything defrosted. Getting a buzzing noise then a click, then buzzing stops. Compressor overload?
Hi!
Leo Ponder
Aug 20, 2011 | Amana ABB1927DE Bottom Freezer...
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
LIGT IS ON IN FRIDGE, FREEZER NOT FREEZING FOOD.
the rtc overload is bad on the compressor,it is held on by a spring wire,remove wire and unplug rtc overload and reverse procedure to re-install this powers the compressor and protects it,also replace the run capacitor on the overload too
Jan 16, 2010 | Refrigerators
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
EVERYTHING FREEZES!
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Sep 24, 2017 | Amana ARB224RCW Bottom Freezer...
Amana ARS266ZBS Side by Side Refrigerator Logo
133 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
