My TV samsung cs15k10mj joins late after about 2 minutes the light-emitting diode blinks prompt please what element it is faulty.
2 Suggested Answers
  • 2318 Answers
SOURCE: Blinking red diode, TV won't turn on.
The power supply is the culprit when the TV fails to power ON. In this case there are shorted diode(s) , defective capacitors or open blown resistors in the circuitry. These power supplies are not longer manufactured, the solution at this point would be to repair it.
Let me know if you require further assistance or you can write to jah2mil@hotmail.com
Posted on Jun 29, 2009
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
Red diode blink black screen
Nov 09, 2013 | Samsung Televison & Video
Picture is on/off (Blinks)
1) test the power button, for open, or faulty and replace.
2) the power supply inside can be short some element such: capacitor,resistor, diode, Flyback, transistor horizontal output.etc.
you can go to the repair shop TV for fix it.
God bless you
Sep 22, 2012 | Televison & Video
Replaced 3 capcitors today and tv still wont power up, element flx3711b lcd tv
check D7 and small cap to the right(forgot # returned tv) in the power supply area.i found diode leaky and cap dry.Thats how i fixed the blinking red light.hope it works.
Mar 07, 2011 | Element Electronics FLX3711B 37 in. LCD TV
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
What is the code for SAMSUNG tv......or how can I manually get the code
Hi! try these steps.. I hope it helps..
1. Turn on the TV.
2. On the remote control, press and hold SET
until the LED blinks twice, then release SET.
NOTE: The remote control will exit programming if
more than 10 seconds elapse between key presses.
3. Enter the first four-digit code for your TV. If
you perform this procedure correctly, the LED
will blink twice.
NOTE: If the LED emits a long blink, the code is
invalid. Repeat steps 2 through 3 and try entering the
same code again.
4. Aim the remote control at your TV and press
POWER once.The TV should turn off. If it does
not respond, repeat steps 2-3, trying each code
for your brand until you find one that works.
The code for samsung tv are:
Samsung 0060, 0030, 0178, 0019, 0056
Jun 10, 2010 | One For All URC-1050 Remote Control
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
