Question about Compaq Presario 5000 PC Desktop
What wrong? First and foremost I am sorry if there is another thread out there somewhere on this subject... I have a computer problem. When I play any games or music, it works fine but every like 45 seconds to a minute, the sound starts to stutter and the video follows suit. Then it clears up and I'm good again. What is wrong, I have already done a system restrore, bought a new sound card, and this problem still presists. any one know what's wrong?
    Guru:
  • 1,342 Answers
How much memory do you have installed in your PC. Adding more memory may help.
Posted on Jun 16, 2008
  • Georgia B
    Georgia B Jun 16, 2008
    I posted my reply to your request HERE
What subjects you need to be a magistrate
none about cameras that i know of. try a courthouse and talk to one.
Aug 02, 2017 | Cameras
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
I am using a finesse 356 sewing machine and the thread keeps on breaking off at the needle. What could be the problem?
Could be threaded wrong. Could be tension too tight. Could be a bad needle. Could be bad thread (avoid old thread or bargain bin thread). The fabric, needle, and thread may not be compatible, ie the thread is too large for the needle's eye, could be incorrect thread for the fabric, the fabric may be too coarse and is wearing the thread and causing it to break... There could be a burr or nick somewhere that is catching the thread. The thread could be hanging up somewhere in the thread path on the way from the spool to the needle causing it to break when it reaches the needle.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwi04JrRs-_NAhWKPiYKHaccBmwQFggzMAI&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles Understanding of Sewing Machine Needles Coats Industrial
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Sewing Machine Problem 1 Thread Breakage
Jul 12, 2016 | Sewing Machines
Bobbin is not catching needle thread resulting in a tangle of thread on underside of fabric
Have you started by pulling the bobbin thread up manually before you start sewing? Your tension is wrong somewhere, could be upper or lower.
Jun 27, 2015 | Sewing Machines
I have a Toyota RS2000 sewing machine. The thread has suddenly started breaking, and I am getting big bundles of thread under the fabric. What is wrong please?
try a top thread tension of 4
change to a new needle
clean under the needle plate & in bobbin area for lint or loose threads
also rethread machine top thread & bobbin just incase thread is catching somewhere
make sure the thread doesn't come off the thread take up lever
check to see if there are any burrs on the needle plate or the bobbin
Aug 10, 2011 | Toyota Sewing Machines
..the right needle thread keeps coming out and I
Sounds like you have a tension problem. Have you re-threaded? Check tension discs for bits of broken thread which may cause jamming. The thread must be catching somewhere. Pull it through by hand to see if it is too tight.
Mar 24, 2011 | Janome Harmony 9102D Mechanical Sewing...
How to fix an 89 camaros rear wheel breaks so they will work?
try this sight. thirdgen.org use the search button and there wil be a thread on this subject.
Mar 25, 2009 | 1989 Chevrolet C/K 3500
My right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Apr 14, 2008 | Logitech Z-2300 Computer Speakers
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
