Question about Maytag Neptune MDE5500AY Electric Dryer
When we turn it on it makes a noise like it needs greased
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 09, 2010
Hobart n -50 where do i put grease in, machine makes a grinding noise
If your N-50 is making a grinding noise there is a strong (almost certain) possibility that the cause is more than just needing more grease.
The sources of the noise are from the transmission case (front portion of the motor housing) and/or the planetary (where the blade attaches).
A search online should turn up the N-50 Service Manual.
With luck, it may be that the two adjustments specified in the Service Manual will do the trick
Three things come to mind regarding the noise:
1) If simply greasing the planetary does not do the trick, then
2) There are two adjustments to the transmission detailed in the Service Manual. And if that is not the cure
3) The transmission housing will need to be removed to find the source of the grinding. This is where the grease is truly encountered.
Sep 04, 2017 | Hobart Food Mixers
Noise in stering colum only when i drive staight, if i turn wheel one way or other noise stops
if you are drive straight all the time than that part of is getting worn out. you mite see if the are any type of grease points on the steering
column, the grease in the center or as you stated driving straight it make alot of noise, the grease has broken down and now it is metal on metal or plastic on plastic. where as you turn right or left it picks up a little grease and soon you will start hearing the noise in any direction because the grease is braking down or drying out.
make sure there enough fluid in the steering control box, mite look for a condition fluid.
Apr 14, 2015 | Cars & Trucks
2006 Cadillac DTS makes noise when the wheel is turned, noise started after wheel bearings were replaced in the two front wheels
If it's a "squealing" sound - check the power steering fluid. If it's more of a grinding sound - then the wheel bearings were not properly "packed" with grease. Note - the grease needs to forced into the bearings by hand while rotating the bearings. I had a this problem myself when a "mechanic" just smeared some grease around the bearings.
Aug 15, 2014 | 2006 Cadillac DTS
Creaking noise when turning steering wheel
Grab a grease gun with a needle fitting. Puncture your ball joint boots and grease them internally. They might just be dry and the fitting might not be getting grease where needed. Try that.
Jan 22, 2014 | 1994 Lincoln Town Car
Have 20,000.00 miles on car and the front end makes a creaking noise when turning steering wheel...need to grease but no grease fittings how do you get rid of noise
most newer cars came that way so you cant grease them this way you almost have to buy after market with grease fittings thay get you coming and going the only thing you can try is p-b blast spray it on the parts and hope it works good luck let me no if you need any thing else.
Apr 24, 2011 | 2000 Lincoln Continental
My honda crv 2000 will make a strange noise when making sharp turns. particularly i notice this noise will sound when just making a turn in the snow. could this be a drive shaft needing grease or something...
It ot is a clacking type of noise and is present only really when making sharp bends I am afraid that either one or both of your CV joints have worn out. It is easy to detect which by listening to the source of the noise. (Grease alone will not fix that problem).
Jan 21, 2011 | Honda CR-V Cars & Trucks
VAN IS MAKING NOISE WHEN YOU MAKE LEFT TURN
It really depends on the noise. If it is a grinding noise or a popping noise then your tie rods need grease. If they do not have grease zerks then you will have to get a hypodermic needle from auto zone and punch a small hole in the boot. Do not worry, grease will not leak out of the hole because it will close back up when the needle is pulled out. I have been doing it to my cars for years, it only extends the life of this part.
Apr 01, 2010 | 2000 Ford Windstar
Car makes noise like a dry wheel bearing only when turning right-rotating tires makes less noise for a while but is still there and steadily gets worse. Nothing is loose in the front end-noise has been...
Look again under the car. Check the CV joints on the side making the noise.
CVs are cover in a rubber "boot" and contain grease the lubricates the joint. Look to see if the boot is torn. If so the grease is lost and the joint will wear and make the exact noise you describe.
Start there as it is a simple and likely issue from your description.
Hope this helps
Feb 27, 2010 | 2004 Volkswagen Jetta
2005 Ford Escape loud squeeking noise when I turn the wheels
check inner and outter berings-torque onhub assy-rim hitting ty-rod endget all fittings greased even if u have to add zirks-check body bolts -torque to spec-tire hitting frame?
Sep 02, 2009 | 2001 Ford Escape
"whinning", dry grinding noise from under riding mower
all bearings that run belts & pullies should have grease zert fittings to lube the bearings with a grease gun check if there is fittings then use a small needle or punch to push down on ball on top of zerts to make sure they are free to alow grease to enter grease them till grease comes out from under neath or the top of bearings
Jun 04, 2009 | Garden
Maytag Neptune MDE5500AY Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
