Question about Lands Phones
Replacement phone charger arrived, i plug it in and it says invalid charger. original charger broken.
    Master:
  • 788 Answers
Do the output values on both chargers match? Voltage and Amperage? Are both chargers of the same model #?
Posted on Jun 16, 2008
Message on my iPhone shows icon for iTunes to plug in a charger. What do I do?
Charge the phone at least overnite. Sometimes a replacement phone may arrive with a totally dead battery and the charger may not be able to put out enough current to operate the phone and charge it at the same time. If you want it to charge faster use a plug in charger with an output rating of 2 amps. They usually have 2 USB outputs and can charge two devices at the same time. If you only charge one device it's a piece of cake for the charger. .
Sep 10, 2014 | Apple iPhone 4S
My i phone 3g 8gb is dead and is frefusing to charge what do i do?
hi there!
it can be caused by battery or the charger you're using. if those are not original iphone batt and charger, replace them with the original once for the imitations (china made, local made) easily gets broken. otherwise, check on the battery's life, if its more than a year and if its everyday used within that perion, replace it, its already dead. but if its not and when you charge it, the phone isnt responding at all, try using that charger to another iphone unit. if all else fails, best thing is to bring it to apple (if its still in warranty) or to your local technician.
Apr 07, 2011 | Cell Phones
I've had my voyager for less than a week, and the place I got it from gave me a generic charger that broke inside the phone, what can I do?
Use tweezers or needle-nose pliers to remove the broken charger from the phone. If you cannot remove it, you will need to replace the phone.
Once you remove the broken charger, buy an OEM (original equipment manufacturer) charger, or a generic one from a respected brand.
If this helped you, help me with a few thumbs up!
Mar 03, 2011 | LG enV VX9900 Cellular Phone
Razr V3M and get invalid charger. I am using the same charger that came with the phone though it is a new battery.
The problem sounds like your phone problem. How old are both the phoen and charger. Who is your carrier. Depending on the carrier you may be able to get the phone replace. If you have are ready purchase a new battery and it is still saying invalid charger more and likely it is the phone. Clean the battery connections with a toothbrush. Also Use can air to blow out the dirt in the charging port. Clean these areas out very well and you should be find. If not contact motorola and have them send you a replacement. If your still getting a invaild charger. You may even be able to get them to send you a charger.
Oct 31, 2010 | Motorola Mobility RAZR V3i Cellular Phone
When i plug it in to the charger it says invalid battery
ik this happened to me too well, wat i did was i kept trying to charge which the thing is that when it says invalid charger thing its becuz ur charger has some nasty things on it so wat i would do is go to ur phone company place and buy a new charger... :D
Dec 21, 2009 | Motorola Mobility RAZR V3
Nokia 6300 dual cim china invalid charger
shud be some software prob. u need to get ur phone serviced
Sep 26, 2009 | Nokia 6300 Cellular Phone
Not Turning On
your charger port is most likely broken. if you try another charger and get the same thing- replace the phone, it cannot be repaired- unfortunately is not covered by warranty (it is if you bought the insurance for it) and once you replace it- NEVER use the original cords from the original phone or it might happn again.
Aug 20, 2009 | Palm Zire 72 Handheld
Invalid Battery
Hi Mari,
You may have a defective battery, or a defective phone....I had the same problem previously.
First, pull out the battery, look at the top and see if the watermark is pink.  Second, if it is an original moto battery, see if your device and accessories are covered by a warranty with your carrier.  Third, test it with a different battery. If the problem still arises, then you may have a defective phone.
Dec 11, 2008 | Motorola Mobility RAZR V3
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
Lands Phones Logo
90 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
