What are the common reasons why my Mitsubishi rear projection tv turns off right away after turning it on?
  • 643 Answers
You could have a faulty power supply or an over heated high voltage unit.... i would suggest calling a mobilet.v. tech shop to have them check it out.
Posted on Nov 09, 2010
The tv turns on, then turns off right away
You have a problem in the High Voltage section of your TV. I would call the nearest tech.
Aug 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When I turn the tv on it turns off again right away
mine did the same thing then when we got it to stay on the picture was all messed up, and we;re hearing it will be quite a repair bill!
Nov 08, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
