Question about Cosco Alpha Omega Elite - Hammer Print
Removing the seat cover from base
Hi i was wondering to remove the elastic straps from the base, how do you remove the base.
thanks
scott and jen
    Problem Solver:
  • 13 Answers
Have you removed the harness?
Once the harness is removed, you pull the top of the back seat down and back at the same time, and the back should be removed.
Can you post the model number from the bottom of the seat if those instructions don't hurt?
Posted on Jun 19, 2008
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Describe how to remove upper back from monarch car seat
Remove the back and bottom covers (the back cover has four clips; the bottom cover stretches over the front of the base and has two elastic bands that stretch back on top of the base). While holding the base on the floor, push the backrest all the way back until flat (this will take some force). Slide the axel off to the right (your right as you are facing the front of the seat).
Oct 04, 2009 | Britax Monarch - Red Racer Booster Car...
How do I take the entire cover off to clean?
remove the belts and there are some elastic straps that attach the seatcover to the seat. they will be hooked onto the back of the seat.
Sep 29, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
I am unable to remove the back to convert this car seat to a booster.
Sep 02, 2009 | Britax Monarch - Red Racer Booster Car...
Need to clean carseat al eddie bauer online manuals aren't availa
First, snap out the black pieces that attach the cover to the seat with a pair of pliers or a kitchen knife. Then turn the seat over and remove the base by sliding out the metal rod that runs thru the base and seat. Then unhook the center buckle from the bottom of the seat and back up thru the seat. Unhook the straps from the metal bar on the back of the seat and thread them back thru the seat. Be sure to remember the order in which you slide it thru the components so you can reassemble. It may be helpful to lay them out in the order you removed them. Unhook the elastic bands holding the bottom in place and slide it over the top part of the seat and off the seat. If you need to remove the top part and wash, remove the black pieces the same way as the bottom, unhook all elastic and slip it off the top. I wash mine in cold water with mild detergent and usually let it air dry so as to not shrink it. Reassemble by reversing steps.
Jun 06, 2009 | Eddie Bauer 3-In-1 with Latch
I need to know how to take the liner out of the baby car seat so I can wash it.
You have to unlatch the shoulder straps from underneath then unscrew the side handle to remove the elastic. Then your able to completely remove the cover. Just pay attention, because getting if off is the easy part, putting it back can proove difficult. Good Luck!
Jul 27, 2008 | Graco SnugRide - Giselle Infant Car Seat
I have a Graco infant car seat and want to remove the padded seat cover to place in the laundry. There are two elastics on either side of the car seat that help secure it to the sides of the handle. I...
What model do you have?
You can call graco at: Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Ensure you do NOT wash the straps/harness, as it will make it unsafe and you will need to replace it.
They also have an online manual fi that will assist you. I checked my seat, and it is an older snug ride with no straps.
Thanks
Apr 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
REMOVING COVER COSCO ALPHA OMEGA ELITE
The straps need to be removed from the metal clip in back, and then the plastic grommets must be pried loose from under the fabric with side pressure and an upward push. Its not easy. Bad design. There are no screws involved, but a standard screwdriver can help with the release. The oblong grommets have ridges that must be compressed to release.
Jan 09, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Cosco Alpha Omega Elite - Hammer Print Logo
483 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
