Question about Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set
How do you change a spindle on a spindle sander?
  • 7,733 Answers
Go to eReplacementParts.com : Power Tool Parts and Tool Repair and find parts and diagrams very useful.
Posted on Nov 09, 2010
MODEL 11322506 MAINT. TO CHANGE DRUMS
To change drums you have to remember it is reverse thread. If the nut will not because the drum keeps turning you need to either squeeze the drum or hold the shaft near the bottom where the fins are. At least this is my experience with the Porter Cable oscillating spindle sander.
Jan 30, 2013 | Tools & Hardware - Others
I NEED A REPLACEMENT GEAR PART NO 1347788 FOR A DELTA 31-780 SPINDLE SANDER
The link below includes the schematic, part list, pricing and ordering info for toolpartsdirect.com
Delta also offers this model in 2 other variations, 31-780 type 1 and 31-780 type-2. Both of this are also available from the page this link will take you to. The part you are looking for is $13.33 and they show 4 in stock.
Have a great day.
Dec 28, 2010 | Delta 31 - 781 Sanding Spindle Set for 31...
I have a stuck sanding spindle in the arbor of my JOVS-10 spindle sander. I have tries penetrating oil to no avail. Any ideas without tearing down the whole machine?
One last idea is just trying to tighten it more to possibly breach the seizure or you could put some torch heat to it to try and expand the metal. I'd be careful torching as all the super-fine sawdust and oil. Good luck
Dec 14, 2009 | Jet JOVS - 10 / 708411 Oscillating...
Changing the sanding pads
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on.  Replace the nut.  You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/a20932,sa350k.pdf
May 30, 2009 | Delta SA350K Shopmaster Boss 1/4...
On the Bench Oscillating Spindle Sander how do you lock the spindle so that you can remove the bolt at the top to change the sanding sleeve? When I try to loosen the bolt the spindle turns and I don't have...
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Mar 09, 2009 | Delta Machinery ShopMaster SA350K Bench...
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Ryobi Oscillating Spindle Sander OSS450 Manual and Sandpaper Changeout
Go to Harbour Freight Website. Their Oscillating Spindle Sander drums & sleeves are direct replacement parts for the Ryobi unit.
Dec 07, 2008 | Tools & Hardware - Others
Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set Logo
251 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
