Question about Whirlpool Washing Machines
Will not spin water drains and you can hear it but no action
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Nov 09, 2010
Pau error 42
I need the make/model but based on the very limited info, it sounds like you have a drain pump issue. If you can hear the pump humming or running, then power is getting to it but most likely it's jammed or clogged. Washing machines won't spin if they can't drain. If there is no pump action at all, suspect drain motor, wiring to the pump, lastly, main control board.
Aug 21, 2015 | Washing Machines
Didn't drain. Won't spin.
Hi Kat, let's see if I can help your with this. The washer will not spin when it senses water inside so we'll start first with the drain. When the machine was finished washing, did you hear the drain pump attempting to discharge water? Try selecting the "Spin Only" or "Rinse and Spin" cycle, you should be able to hear whether or not the drain pump is attempting to operate. If you do hear it running, but the water is not draining, it is possible that the drain filter is clogged. If you need instructions on how to clean the filter let me know. Otherwise, we'll move to the next step.
Mar 07, 2015 | Samsung WF203ANW Front Load Washer
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
Wash but not spin cyecle
Check whether the water drain taken place. if all the water drained, the spin will start. A little spin action first and full spin later. ( depends on the program design)
even after drain there is no spin, it could be water level zero not sensed or timer/micro controller needs to be checked
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
Washer drum not spinning
yes you will most likely need a belt.
Mar 11, 2009 | Kenmore Washing Machines
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Worthwhile to repair?
Hi thanks for the question The problem yhat you have is with the lid switch or the striker .the striker is located on the lid top right corner . If the striker is there then replace the lid switch Thanks for the question The appliance doc
Sep 12, 2008 | Kenmore Washing Machines
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
