Question about Samsung LN-S2641D 26 in. LCD HDTV
Base Detachment When I got the T.V the table stand was already attached. Now I need to put it into the box for safe transport and I can't figure out how to get the stand off. I know it comes off because the screen can be mounted on the wall and came with a cover to fit over the hole in the bottom of the T.V where the stand fits into. My question is: what do I need to do so I can get the table stand off the T.V?
If you lay the TV down on something soft but firm (towel on the floor or counter) put the screen face down on the back you should see 4 screw holes with the an (S) next to them. They are located at the center near the bottom. If you remove these screws the stand should then slide out of the bottom of the TV. Good Luck
Posted on Jul 13, 2008
I need a replacement base stand for this tv. Any help with this?
Shop for base stand for tv on Google
Television Stand Assemb...
$15.10
Sears Parts D... Sanus EFAB?B1 ? Modular Aud...
$79.99
Google Trusted StoreThe Simpl... Atlantic Furniture Tabl...
$32.78
Walmart Convenience Concepts Des...
$39.99
Google Trusted StoreWayfair Atlantic Table Top TV Mount...
$24.88
Jet.com Search Results
    Universal TV Stand / Base + Mount for 32" - 60" Flat-Screen...
    www.amazon.com/...Stand-Base...Flat.../B00DZVPFG...
    Amazon.com, Inc.
    Rating: 4.6 - ‎492 reviews
Jan 10, 2016 | Televison & Video
Where can I buy a replacement base?
MFG website or customer service email. They really need to know this is a problem for safety reasons. And may help with a new part.
Jun 07, 2015 | Saws
Where can i find a base stand and attachment for my flat screen
You can buy universal stands, I use MCM electronics but there are many others to chose from.
Aug 08, 2014 | Emerson LD190EM2 19 in. LCD HDTV
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
How to put the stand back on a plasma tv
most of the time the set has to be laid face down "safely" so no weight or stress is on the actual front screen---the base then should be safely attached and the 4 or more specific bolts attached.
It can be done with 3 people--2 holding it up and number 3 attaching the base........
Oct 29, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Are there aquarium filters that I do not have to put into the tank itself? Maybe something that can work from the outside?
Yes. There are both internal and external filters. External filters are normally hung outside the aquarium or placed under it inside the aquarium stand. Some of these filtration systems include power filters and canister filters.
Aug 14, 2012 | Fish
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
I want to mount my HCT TV (Mod # HLD 320TB) on the wall but have not been able to figure out how to get the table stand off. I have the wall mount already attached to it.
There are four screws on the back of the tv that have an s near the screw hole. Unscrew and slide mount off. On the base unscrew the 4 screw and reinstall the cover to the tv. Install the 4 screw in the holes that have an s on them and you are done.....
Hope this helps
Buzz
Sep 21, 2009 | Televison & Video
Samsung 4235X/XAA older Plasma TV Need to take the base out for m
GENTILITY lay that set face down on a table covered with a thick blanket. There should be 4 long threaded bolts near the bottom that fasten the legs of the stand inside the framework of the set.. Remove these and the stand should slide right out.
www.mcveyelectronics.com
Apr 11, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung LN-S2641D 26 in. LCD HDTV Logo
950 people viewed this question
Henry  Thomas
Henry Thomas
