Change default setting for pixma500 printer - Office Equipment & Supplies
    Guru:
  • 1,342 Answers
You can download the User's Manual for your printer from Canon HERE
Posted on Jun 16, 2008
  • Georgia B
    Georgia B Jun 16, 2008
    Why was this rated as inappropriate? The User's Manual would certainly be the place to look.
How do I change my default print settings
To change your default printer, simply go to start, then settings, then to printer and faxes from there you will find the printer and double click the printer that you want to become your default printer. It will show the check mark to that printer that you choose. Good luck!
Sep 20, 2011 | Epson Stylus RX690 InkJet Printer
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
How to set printer as default
  • Click on the Start menu and click on Settings, then Printers.
  • A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  • Click on Set as Default
  • To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
  • Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz14tGsLTEN
    please leave feedback if this helped you :)))
    Nov 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
    I have a cannon pixma500. i have never got it to print color. what can be wrong? i have removed all n cleaned w alcohol pad. also all r brand new catridges from original cannon
    There is a setting that can be accessed via your computer under printer set up. It sounds like the printer has been set up for monochromatic prints.
    Aug 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
    How to get off of current settings to default setting
    press menu to get to system settings
    use > to get to restore default
    ok
    Eric
    Jun 20, 2009 | Canon PIXMA MP180 All-In-One InkJet...
    Hi I have HP PSC1610 printer-copier-scanner. 90% of all my printing I do in "FastDraft" Paper Quality. The default is in "Normal" Paper Quality and I have to change the settings each time I print. I would...
    When you print from the Microsoft Word and while printing you change the Printer Properties and Print Quality to FastDraft
    Everytime you close the window the setting gets reset and again when you start, you have to do the settings.
    The Solution you are looking out is
    Go to Start >> Control Panel >> Printer and Faxes
    There you choose the your Default Printer HP 1610 >> Right Click
    and Click Properties
    Then you choose Printing Preferences and Make Choose FastDraft
    This setting will remain as your default setting now
    So whne you have to Print Normal Mode
    You need to change the Properties from Microsoft Word.
    and it will reset everytime you close MS Word.
    Cause your Default setting then is "FastDraft"
    I hope this solves your problem
    all the best
    Jan 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
    Can I set default printing to black and white for color laser printer?
    Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
    Hope this helps, and please rate my advice, good OR bad.
    Feb 05, 2008 | Office Equipment & Supplies
    Change default settings
    Open control panel , click printer Icon as yo wish to default , click eefault.
    Dec 28, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    107 people viewed this question
    jasbo
    jasbo
