Question about Canon BubbleJet i9950 InkJet Photo Printer
Printer problem This printer was working fine on my boss' Applemac. However, I am trying to use if on my PC and laptop using Windows PC. I set it to A4 or A3 and although in the print preview frame it shows the correct sizing and all other settings are correct, it reduces the print area when printing out so it shrinks to only about one quarter of the size i.e. if I send something to print at A3, it prints out at A5. I have tried all the suggestions that Canon have offered me but nothing works. Be grateful for any advice you can give as it seems to shame to have to buy a new printer. Thank you.
  • kimmomo Jun 16, 2008
    Thanks, but have tried all the most obvious things - as you suggested, but still the same problem.
  • 2,058 Answers
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Posted on Jun 16, 2008
Epson how to install
Are you running Windows or AppleMac If so:
1. Install the programs off the CD, which I assume came with the printer.
2. No CD... Go to or , click on SUPPORT/printers, choose your printer and operating system and install the neccessary drivers
If you are using the BEST O/S on the planet...LINUX:
Jul 31, 2014 | Epson Stylus Photo RX520/RX530
My Dell Inspiron 1545 has stopped printing
first check the printer cable
then try to uninstall the printer driver
restart the laptop
try to install the driver again
print the test page
Feb 06, 2013 | Dell Inspiron Computers & Internet
X2670... printer can not communicate with computer
Did you reboot the PC after uninstalling printer?
Unplug the printer from the PC and from power.
Uninstall it from your PC and reboot it.
Connect the printer and turn the PC on.
Mar 03, 2012 | Lexmark X2670 All-In-One Printer
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\ shared name where is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
the password it is asking for is probably the administrator password. If there is someone else that uses the computer also they may be set as the administrator and you probably have a normal user account.
YOu need to get the administrator password before you can install the printer. If this seems to be a normal problem for you then you should have yourself set as an administrator(control panel>user accounts))
Let me know if this helps with your problem and thanks for using FIxYa
Jan 07, 2009 | HP Computers & Internet
Driver required for HP laserjet 1018 with Applemac OS 10.4.10
Unfortunately, the 1018 is not supported in the mac environment.
Unless you are familiar with changing the source codes from linux to MAC I wouldn't attempt it.
The other option would be to set the printer up on a different machine as default and using a program like NETWORK MAGIC,
network the computers together and share the printer, Use the trial version first to see if it works.
Mar 19, 2008 | Computers & Internet
Kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Mar 08, 2008 | Kyocera Mita KM-5035 Printer
Connecting Toshiba laptop using windows vista to C7180
Hi there i know that HP are updating a lot of the drivers at the moment you could try the following websites (Free download) (Small charge)
I hope one of those helps but also try the XP driver as may vista might work on XP driver technology.
Thanks J
Jan 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
Canon BubbleJet i9950 InkJet Photo Printer Logo
123 people viewed this question
old marine
old marine
