Question about Polaroid FLM-3201 Television
For a couple months now whenever we turn on the tv the screen remain blank, slowly we hear static and the image will begin to flash slowly. The images flashes faster and faster until it is finally solid and showing like normal.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U have 2 bad capacitor on power supply , if u take the back cover off and take a look at the power supply u would see 2 bad capacitor they are on top exploded
Posted on Nov 09, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I have bought a new philips colour tv just 3 months ago.after watching tv for sometime whenever i power off the tv i can see some colour spot red,green....on the centre of the screen.even after removing...
This problem is known as image retention and is a problem with the PDP. Turn on the set when you see these spots and see if they appear on the image too. If they persist, then its time to use your warranty to get a replacement.
Dec 31, 2010 | Televison & Video
I have a 51HW40 sony TV. A few problems green horizontal retrace that curves flashes green and turns off (about 2 times a month) I wait turn it back on and its fine Codes that have been tripped: 6: Low b ...
Hello: Have you tried to adjust you Green Screen control on the focus block assembly. located behind the front panel assembly. Here is a solution that might help you, turn off the green by turning off this control, make sure u look at the block and make sure you are not turning the green focus knob instead of scrn crl. Turning the control slowly to the left the retrace lines should disappear as the green video darkens. Then turn the control slowly to the right just until the retrace lines reappear, then turn back slowly left just until the lines go away. If the screen is Blanking on green tube only then you have a video blanking problem on the main signal board. Or possibly a IK bias problem. It is also possible that the green CRT is defective. The FBT is not bad because the screens are lighting up indicating you have high voltageand heater voltage which is derived from one of the secondary windings of the FB. If it is a Blanking problem i would look into replacing the A Board assembly.
Sep 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Computer turns on but screen wont
First,If you are running windows vista,This can be due to an update that has your video driver and windows video driver running at the same time.
Hardware would be the invertor board is bad.
Ttry to start with F8 and choose start in vga mode,If this allows you to start normally,go to the device manager and update the video drivers
Feb 22, 2009 | Toshiba Satellite P205-S6337 Notebook
Swicthed on tv and its a blank screen..now it wont switch off.
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
lone99star
Jan 09, 2009 | Samsung Televison & Video
Slow to come on, picture flashes black, 32" SONY tv
blankenship, the "IK circuit" is blanking your screen, only "fix" is temporary, remove back of tv, and on rear right side (facing into the back of the set) you can see 2 philips type plastic screws mounted on the flyback transformer, one is focus the other is screen, do not adjust focus , turn screen control clockwise slowly until you get white retrace lines on screen, then turn counterclockwise until retrace lines disappear, this increases drive from tube to IK circuit, will last anywhere from 6 months to 18 months and then it`s replacement time, questions? e-mail me back. good luck, BMW Rider
Jan 11, 2008 | Televison & Video
My TV won't come on!!!
you have powersupply problem .you wil have to have it checked by tech sorry
Mar 22, 2007 | Sony KV-27V42 27" TV
Polaroid FLM-3201 Television Logo
546 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
