My toddler started pressing a bunch of keys on the keyboard all at once and so I shut the laptop and when I went back later to try and turn it on it wouldn't go. I can't get it to boot up at all. Any suggestions? Thanks.
    Genius:
  • 1,148 Answers
Try restarten cpu,,k ,,imediatly press esc buttonn,,jus keep tapping it,,it should go to a boot option screen,,tell it to boot from hdd,,hard drive,,press the number that is next to hdd on screen,,ok should be good to go,,ok,,goodluck
Posted on Nov 09, 2010
Keyboard problem
Try pressing both the left and right CTRL keys at the same time and
see if that releases CTRL.
Go to Start / Settings / Control Panel / Accessibility Options /
Keyboard Options.
Turn off CTRL lock if it's on.
If that solves it and to avoid future problems, press "Settings"
Turn off "Press modifier key twice to lock".
Turn on "Turn sticky keys off if 2 keys are pressed at once".
Or turn off "Use shortcut"
Clean your keyboard.
Cleaning Laptop Keyboard
http://www.computing.net/howto/simple/keyboard/
hope this helps
Sep 04, 2012 | Compaq Presario C716TU Laptop Charger...
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
Keyboard of myASUS K50IJ-XA1 15.6-Inch Versatile Entertainment Laptop (Black) is locked How to unlock the same? Kindly help
Well, do you mean only the keyboard is locked? Can you boot the system properly? Is the mouse working? Which Operating System is running on your Laptop?
Here are a couple solutions you can try before you let me know the above queries.
1. Press and hold down the Windows Logo key on the keyboard while pressing the L key on the keyboard once. In other words, Press Windows Key + L once. If this doesn't work, don't forget to include the Fn key while pressing these two keys. Windows+Fn+L. Still nothing?
2. Turn off the Machine, remove the battery and unplug the charger. Leave it for at least 10 seconds, you can press the power On button on the laptop without the battery and the charger installed/plugged in. Now re-install the battery, and turn back On the machine. It should work.
If you need further help, if the problem persists, Let me know with the details.
Good Luck.
Thanks for using FixYa.
Jul 24, 2011 | ASUS K50IJXA1 156Inch Versatile...
I have a dell inspiron 1545 laptop(2 yr old).i cleaned 2 weeks back with colin cleaner meant for cleaning itafter i did n started it started to beep continuously for few secs and the screen blinked.So i...
Try re-seating the keyboard, here is a link to dells website showing you how to remove the keyboard...it's not a tricky thing to do but do take your time and follow the instructions.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/keyboard.htm
Once the keyboard is removed have a look for any liquid ingress from the cleaning, just pat down with a paper towel and replace the keyboard and restart, let me know if this helped.
Mar 21, 2011 | Computers & Internet
When I write text on the laptop keyboard, only numbers show but no letters. what to do?
Try reset your laptop. Remove the battery and allow 1 hour before re-inserting the battery. Then get back to me what happen.
Nov 04, 2010 | IBM Thinkpad 560 Series Laptop 20h4241...
My motorola k1m krzr shut off yesterday on its own and when i went to turn it back on i pressed the pwr button and the key pad would turn on as long as i would hold it but when i let my finger off the pwr...
I'm not going to bid on this because its simply a tiny transistor that is burned out and there is nothing you can do about it but send it back for repair or replacement. I'm sorry about that.
Sep 21, 2010 | Computers & Internet
Laptop button not working
Press alt+ctrl+fn
Most of the time this will work.
1. Try pressing both the left and right CTRL keys at the same time and
2. Go to Start / Settings / Control Panel / Accessibility Options /
Keyboard Options.
3. Clean your keyboard.
If not working, comment back. All the best.
Apr 06, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Laptop keyboard locked, due to toddler pressing keys.
try this go to start>>settings>>control panel>>accessibility options. Uncheck on the keyboard tab and uncheck everything under keyboard
Dec 22, 2009 | Computers & Internet
Reset my laptop to its factory default?
the first thing if it is windows xp on it then in order to reset ur computer back to factory settings u need tofirst shut down the computer and then press and hold down the ctrl key on the keyboard and then press the power button only once and keep tapping f11 key on the keyboard and after that select the option that says complete restore to the manufacturer's settings,and if u have vista all u need to do is shut down the computer and then press the power button only once to turn on the computer and i mmediately keep tapping f8 on the keyboard it will take u to the advance options u need to choose repair my computer and then select complete pc restore to the manufacturer's setting and follow the instructions.....thanks
Jan 22, 2009 | Sony VAIO VGN-UX280P Notebook
Operation of computer while connected to F380 .
Hai
I understand that your Isue is "After installing the HP All-in-One software, the computer stops responding during start up when the All-in-One is connected and turned on. The computer will start correctly if the All-in-One is not connected or is turned off."
SOLUTION:
This problem can be resolved by changing the "USB Emulation" in the Computer BIOS settings.
If you are using a DELL Computer just follow my instruction below.
Caution:
If you are using a USB keyboard, do not disable “USB Emulation”, “USB Keyboard Support”, or “USB Legacy Support”. If the settings must be disabled, use a PS/2 keyboard
Changing the BIOS on a Dell Dimension computer
Follow the steps below to turn off the ability to boot from USB devices but still support a USB keyboard while starting. Contact Dell for assistance if necessary.
  1. Shut down the computer.
  2. Unplug all USB devices other than a keyboard.
  3. Start the computer. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press the Down Arrow key to highlight Integrated Devices (Legacy Select Options).
  5. Press the Enter key.
  6. Press the Down Arrow key to highlight USB Emulation .
  7. Press the Space Bar until the “ No BOOT ” option displays.
  8. Press the Esc key twice to go to the Exit menu.
  9. Plug the USB devices back in.
  10. Ensure that “ Save Changes and Exit ” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Changing the BIOS on a Dell Laptop PC.
  1. Shut down the portable.
  2. Unplug all USB devices including USB keyboards.
  3. Start the laptop. When the Dell logo displays, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen displays, wait for the computer to finish starting up, shut it down, and then try again.
  4. Press and hold the ALT key while tapping the P key until a screen displays that includes the words “ USB Emulation ”.
  5. Press the Down Arrow key to highlight “USB Emulation”.
  6. Press the Right Arrow key until the “Disabled” option displays.
  7. Press the Esc key once to go to the Exit menu.
  8. Plug the USB devices back in.
  9. Ensure that “Save Changes and Exit” is highlighted, and press the Enter key. Contact Dell for assistance if the problem still exists
Change the BIOS on computers from manufacturers other than Dell If you do not have a Dell computer, contact the computer manufacturer for assistance. If the manufacturer does not know how to disable starting from USB devices, they may be able to change the order (boot order) of the disks the BIOS uses to start the computer. Move the bootable USB devices selection lower on the list than the computer hard disk drive. If you have any further queries or if the problem still persists, reply me. Thanks Riz (jack_36623@yahoo.com)
May 20, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
