Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
The machine keeps giving me an F1 what is this please...I do not have the manual??
  • Whirlpool Master
  • 1,902 Answers
Hello
F1 error with your whirlpool cabrio is a common issue with these types of washers. This error indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known issue for them. Please get back to me if you have any other questions.
Kevin
Posted on Nov 10, 2010
WHIRLPOOL CABRIO WTW6400SW KEEPS GIVING ME AN F1 ERROR
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Oct 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer keeps shutting off and F1 shows up on the display.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
Wash macahine keeps stoping in the middle of a cyle with an F1 code & I don't have the manual
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The code F1 keeps blinking and I can't shut it off.
f1 means u have a leak on your machine and the water has triggered the flood switch underneath the lower drawer. if u need more help please reply.
Apr 27, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
