Question about Sharp AR-M355N Copier
HOW DO I REMOVE PAPER FROM THE STAPLER COMPILER?
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: I need to remove paper form the "stapler compiler"...
It is inside of your sorter on the left hand side of the copier
Posted on May 23, 2010
.CENTRAL PNEUMATIC staples go right through insulation paper how to adjust
quite likely still too much pressure .personally I prefer a slam hammer stapler for that task .
Nov 19, 2017 | Staples Tools & Hardware - Others
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
Sharp code f1-87
This was a common problem with these finishers. It has to do with the stapler unit rotation binding up as it moves into the stapler compiler. Even if you don't use the stapler, it still does a diagnostic test at power on. Here is a cheap easy fix that usually works. First you need to open the finisher front door where the staple unit is located. Remove the white inner cover of the finisher that you gain access to the stapler through-about 5 screws. You will see a blue solonoid in the upper right hand corner. There are tick marks etched into the metal frame, take note of the position of the solonoid to these marks. To adjust the solonoid, open the door on the right side the paper exits and look at the back of the frame where the solonoid sits. You should see two small phillips screws about 2 to 3 inches apart. Loosen them and change the position of the solonoid referencing the tick marks. This will change the angle the guide hits the stapler compiler, which is usually the cause of these error codes. I would not recommend spending 700 dollars to try and have this problem fixed, because after some time it will come back. You can also try opening the right finisher door and look down into the finisher. You will see two belts and two plastic fingers about 4 inches long with a point on the end. Take some fine sand paper or a small file and file down the back bottom side of those fingers. It is a tight fit to get back behind them. You want to remove any small nicks in the plastic that have formed by the stapler guide hitting them. Good Luck
Jul 25, 2012 | Sharp AR-M455N Copier
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
The paper has jammed and I can't get the stapler to release
Nicola,
1. Hold the end of the stapler (just above the paper) with both fingers of one hand (you might need to hold it with a pair of pliers). The key here is to NOT pull on the top of the stapler, but rather on the (usually silver colored) part that is flush against the paper.
2. Using your other hand, pull on the "tongue" side of the stapler (under the paper). You might need to use a knife to pry between the paper and the "tongue" of the stapler.
-Kieron
Mar 09, 2011 | Office Equipment & Supplies
I need to remove paper form the "stapler compiler" and I don't know where that is.
May 21, 2010 | Sharp AR-M350U Copier
How to install c++ compiler in windows xp pc if already c compiler existed?
Un-install the existing compiler (Control Pannel > Add or Remove programs).
Feb 12, 2010 | Borland Turbo C++ 2006 Professional Full...
Sharp AR-M355N Copier Logo
1,482 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
