Question about Compaq Presario 5000 PC Desktop
Disc drive hi.. my disc drive wont load cd's nor dvd's yet it was yesterday??? any tips would be great..
  • kaiote Jun 16, 2008
    thanks for replying pal, i will try and clean the lens first
  • 4,889 Answers
Does it eject? If not then its a power problem. If the disc tray does eject and load then it can probably be a lens problem First try to clean the lens with a lens cleaner CD.
http://www.nulime.com/CD-DVD-Radial-Disc-Cleaning-System-laser-Lens-Cleaner-Value-Pack/p207841
If it still doesn't work then its a problem with the lens assembly and it has to be replaced. Good Luck!
Posted on Jun 16, 2008
  • eagle338
    eagle338 Jun 16, 2008
    You are welcome. Good luck!
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
Pc wont play are load any disc
Good day..I think the problem would be your cd or dvd drives,you better replace it..tnx
Aug 16, 2011 | Compaq Computers & Internet
I have a IBM thinkpad that has a cd drive only. Is there a way to take out the cd drive and install a drive that is for cd's and dvd's. If so, how would I go about doing that and how much would it cost?
Hi, what it the model of your DVD? Please the correct driver here : www-307.ibm.com/pc/support/site.wss/TPAD-MATRIX.html
Other tips : CD and DVD drive troubleshooting
  1. Verify the disc media used.
    Try multiple original discs (not burned copies) which are clean and free of scratches. See Information about CD and DVD media.
    Note: Dark colored discs such as black may be more difficult to read.
  2. Verify that the disc is seated properly in the CD-ROM, CD-RW, or DVD drive.
  3. Verify that the drive is seated properly in the ThinkPad system by reseating the drive.
    If another similar machine is available, then verify that the drive works in the other machine and that the other drive works in this machine.
    Notes:
    • The CD-ROM, CD-RW, or DVD drives cannot be removed in ThinkPad G40 and R50e systems.
    • Shut down, remove the power cord, and remove the battery from the ThinkPad system before removing the CD-ROM, CD-RW, or DVD drive.
Feb 09, 2011 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
DVD will not read disc,, we've tried 5 different discs. Says loading then it says stop then after a while it goes to screen saver LG DVD player model K 715
Take the shell off of the chassis,and look for the cd/dvd drive. It may be easier to eject the tray then unplug and try to get to the laser.
Get a Q Tip,and some denatured/rubbing alcohol.
DO NOT SATURATE THE Q TIP,only 1 or 2 drops will suffice. Spin the q tip between your fingers while gently pressing against the laser,and make sure the laser has no residue on it,let dry for about 1 minute.
Leave the shell off,plug the unit in after putting a cd in (not dvd,just an audio cd for now) and test. If it works,try a dvd,if that works,reasssemble the unit and try once more. If it works still then great job,you saved yourself a few hours,and a good bit of money.
If it doesn't work,either the laser is not clean,or the laser is burned out.
Nov 01, 2009 | Televison & Video
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
Won't recognize a blank dvd in drive
Clean the drive with a cd/dvd cleaner. Sounds like the read optics are a little drity.
Nov 07, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Compaq Presario 5000 PC Desktop Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
