Question about Dell Dimension C521 PC Desktop
AMBER POWER LIGHT WON'T BOOT GOES IN POWER SAVED MODE
  • 386 Answers
Hi Good day!!! Just open you computer up and switch the little jumper on the motherborad that usually says "CMOS CLR" by hooking the 2nd & 3rd pins together. Than turn you computer on and it will boot up normally, then switch jumpers back. if you need to, change the power saving settings that are in the bios.
Reply if you have any problem
Thank you for using FixYa
please accept if my solution helps you
Posted on Nov 09, 2010
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Monitor not activating
Sounds like will need component-level electronic troubleshooting, probably in the power supply section.
Jan 02, 2007 | HP Pavilion MX70 17" CRT Monitor
Dell Dimension C521 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
