Question about Danby 17 in. DDW1802W Designer Series Built-in Dishwasher
My danby 1802 dishwasher will not fill with water
  • Danby Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Nov 09, 2010
How do I fix my Danby Dishwasher? It fills with water then immediately drains.
Most likely the flood switch is triggered. This causes the pump to operate as soon as you start it. Check if the float at the base comes up when you press it by hand. If not the float spring might be stuck and pressing the flood switch underneath.
Sep 01, 2014 | Danby DDW1809W Builtin Dishwasher
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
I have a water-softener dispenser in my Danby 1899 W Portable diswasher. I do not know how to fill the dispenser and I cannot run the dishwasher until this is resolved. The user manual provides no...
I couldn't find it either for a long time:
1) Pull out the bottom rack as if you were putting dishes there
2) Look at the bottom of the dishwasher and there will be a white circle (near the upper left side) where you can add the water softener.
I didn't use any for a while and the dishwasher worked great so I'm not sure why you can't run it.
Sep 30, 2010 | Danby DDW1899WP Portable Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Danby DDW396
Robin,
Does your dishwasher runs? Check the water control knob, is it ON position?, check fill valve solenoid connector if not connected it is not going to sense water.
Jul 23, 2008 | Danby 22 in. DDW396 Free-standing...
Danby 17 in. DDW1802W Designer Series Built-in Dishwasher Logo
428 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
