Question about HP 610 Color Copier
I have an hp pavilion dv4 laptop and an hp digital copier 610.I do not have the usb cable.it's gonna work with wireless?
  • HP Master
  • 5,159 Answers
This is a USB unit. If you use a wireless print server (for a USB printer), you may get some of the functions to work wirelessly. You will need a USB cable to do this. However, most print servers do not handle the bi-directional communication for the scanner. (You will be able to print if you have the correct driver installed.)
As far as I know, this printer can't be fitted with the HP Jet Direct module (this is the internal print server for some of the HP printers). However, there are external JetDirect options: http://h10010.www1.hp.com/wwpc/us/en/sm/WF02a/18972-18972-236253.html . Check the specs for each model to see if they are compatible with your printer. (The first wireless one isn't compatible as far as I can tell.)
USB cables are available at most stores. Make sure to get one labeled A/B Male/Male ends. For best results, the printer should be directly connected to the computer (or connected to a powered hub). The cable should not be more than 6' long.
I wish that I could be of more help.
Posted on Nov 09, 2010
Laptop turns off when optical drive start to work
i will start with a battery test looks like the motor is drawing too much current for ac support only .
Jul 13, 2013 | Pavilion HP Pavilion DV4-1225dx AC Adapter...
Pavilion DV4 screen wont turn on.(Overnight problem)
Since you have graphics on an external monitor, the problem is the Video Cable, or inside the Display Assembly.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860431&lc=en&cc=us&dlc=en&lang=en&cc=us
This is a general example of a Video Cable, (Display Cable - HP), for an HP Pavilion DV4 series of Notebook PC,
http://www.ebay.com/itm/NEW-ORIGINAL-HP-PAVILION-DV4-LAPTOP-LCD-VIDEO-CABLE-DC02000IO00-486878-001-14-1-/281038275215?pt=US_Laptop_Screens_LCD_Panels&hash=item416f2fc28f
Mouse over to enlarge
The Video Cable connects to the motherboard in an area under the Keyboard, (About where the Fn key is), routes up along the motherboard, then routes up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter (Display Inverter -HP), and back of LCD screen.
It also connects to the LED backlight.
Either connections are loose, or the Video Cable (Display Cable) is damaged.
If the sheath of the cable shows apparent visual damage, so may be the tiny wires inside. (Stretched/Broken)
Connections CANNOT just be visually determined if they are loose.
You MUST physically check EACH connection.
Tightening connections does no good?
Perform a continuity test with a multimeter set to OHM's, on every wire in that Video Cable.
Have an assistant gently wiggle the cable in the middle, and check for an intermittent reading on the multimeter. Indicates broken wire if intermittent reading shows.
OR,
Take Video Cable to the nearest small computer store, and have the resident tech check it for continuity. Should just be a couple of bucks.
Use an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge)
Average cost is around $3 to $6.
Here is the download page for the free Service Manual, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3860431&
Scroll down, click on -
HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
Page 92 (PDF page at Top) for motherboard side of Video Cable (Display Cable - HP)
Page 80 for LCD screen, and Screen Inverter (Display Inverter - HP), and LED backlight.
Page 82 has false statements.
Remove the display assembly:
1. Locate the wireless antenna cable (1), and remove from path (2)
Should be;
Locate the DISPLAY CABLE (1), and remove from path (2)
2. Disconnect the wireless antenna cable from the system board (3)
Should be;
2. Disconnect the DISPLAY CABLE from the system board (3)
Somebody was on crack that day.
The wireless antenna cable information that follows, is correct.
Video Cable (Display Cable) is on the Left side.
Wireless Antenna wires are on the Right side.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 13, 2013 | HP NB199UA Pavilion Notebook
Wat d price of hp pavilion dv4 1030ee charger price in india
buy one from eBay for less than $15
http://www.ebay.com
Just search for hp pavilion dv4 ac adapter or hp pavilion dv4 1030ee ac adapter.
Apr 29, 2012 | Computers & Internet
Wireless botton not working
Which Operating System are you on? Vista, Windows XP or Windows 7?
What do you mean it is not working? You switched it on? Are you connected to your wireless network? If not, do so. Also you should be able to view available wireless networks to make sure the wireless is on.
There is the possibility that your wireless card inside the computer is bad.
Apr 02, 2012 | HP Pavilion dv4-1145go Notebook
Instruction manuel book for the HP Pavilion dv4-2145dx AMD/ATI Entertainment Laptop And initially the switch on buton for this laptop
For HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
http://h10032.www1.hp.com/ctg/Manual/c01963667.pdf
For other manuals for HP Pavilion dv4-2145dx Entertainment Notebook PC http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=4121133&
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Tablets & eReaders
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
How to connect wireless internet connection on an hp pavilion dv4 series?
first make sure the wireless button is on and it should be blue.
next go to start-connect- select the network click on connect.
Oct 20, 2009 | HP Pavilion dv4000 Notebook
How does the media card reader work on the side of the hp pavilion dv4. It is supposed to allow for a ms/pro but it just kind of falls in. It almost looks like an adapter is supposed to fit in the slot
The Digital Media Slot supports the following digital card formats:
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Secure Digital (SD) Memory Card
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type H
● xD-Picture Card (XD) Type M
Here's how to use the memory card reader:
Jul 14, 2009 | HP Pavilion dv4-1140go Laptop
HP 610 Color Copier Logo
Seeker5211
Seeker5211
