Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
FDW60 not heating / Delicate light flashing.........
Having looked through the forums, the delicate light (indicator 6) means; Timeout looking for heat.
I have checked for continuity across the heater terminals, which is okay. The resistance over the same is approx 20ohms.
Just had the front panel off to check the Thermistor. At room temperature the resistance is approx 24kohms, dropping to approx 3kohms over a heat source. After getting down to 3kohms, it suddenly jumps to 2300kohms.
Also, on the Control Board, there is evidence of slight burning around the solder terminals of the two spade connectors, though continuity is good.
I am going to recheck the heater readings just to clarify.
In the meantime, can anyone tell me what reading I should seeing across these two components, and also, which one is most likely at fault.
Thanks.
  • 868 Answers
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
Fdw60 is flashing fast and delicate lights
The code is a10 this is normally a heating issue but could also be a foaming problem which could also be your poor washing results put a cleaner through with a lime scale remover
Jan 24, 2014 | Hotpoint 24 in. FDW60 Free-standing...
I have a Hotpoint SDW 60 problem! The dishwasher starts and goes through pre-wash but stops with just the 'Delicate' light flashing. Does anyone know what the problem may be?
If the original light flashing that means it indicate a fault in the heating circuit. Heater, wiring, thermistor / pcb. (Main control board).
The new flashing light, PreWash (this is the only one on my list for a fault code indication). indicates a fault with the thermistor.
You would need to check by taking the door apart that the thermistor hasn't come off it's mount by the dispenser.
You would then need access to and be able to use a multimeter to test the heater and wiring to ensure they are closed circuit.
Jul 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
FAST 40 DEGREE, DELICATE 50 DEGREES & SALT REFILL LIGHTS ARE FLASHING, WHAT DOES THIS MEAN?
40 and 50 degree lights are flashing on my free standing fdw60 hotpoint dish washer
Apr 15, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Delicate light flashing will not dry
Post more information about your problem if you need more help....
Good Luck!!
Thanks
Aug 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592rc_a04.gif on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like what the flashing fault codes actually refer to, note what follows are pointers to what bit has gone wrong only. You should have the programmes running left to right: led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate wash.ok so when this heap of western european tosh goes wrong one or two lights will flash this is what they mean:led3=m/ch has o/flowed water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s or slow fill.5=thermister(electronic thermostat) is u/s or more likely the pcb .6=timeout heating which means the thermister senser between the door halves has become faulty or detached.3+4=no pump out,slow pump out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming on -seized,winding o/cic.but can also mean mesh plte filter badly blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t except any responsiblity for this being spot on or near spot on!! hope this helps someone.Try NOT to electrocute yourselves please!! If your not at all confident walk away and get "someone" who knows what they are doing.Cheers. jawa592
Jan 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
AQUARIUS FDW60. THA FAST AND DELICATE LIGHTS KEEP FLASHING.
I had the same problem with my Hotpoint FDW60 and read all the online reviews about how baddly made the FDW60 is and after taking it apart I totally agree.
As the warning lights were indicating a faulty heating element I checked it to find that it was not working. I bought a replacement for £43 at my local electrical store (I think they then ordered it online). Taking the bottom off is easy but once off, it is very difficult to actually get to the element, but it can be done. I had to buy new hose clips to fasten the rubber pipe each side too. It has been on twice today and so far so good.
I have read some message boards and have seen that some people have had to replace the element a number of times, so I will wait and see what happens.
Be aware the heating element is not your usual heating element, it looks more like a insulated metal tube: http://www.buyspares.co.uk/cgi-bin/search.pl?query=heating+element+fdw60
Good luck
Rob
Jan 18, 2009 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius FDW60
I think you will find that the heater has packed up.same thing has happened to my 14month old machine.
Waiting for the part to arrive approx £40 looks quite straight forward if you are a bit handy with tools
Dec 23, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher stops inbetween rinse and dry
hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Jun 15, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
306 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
