Question about Woods 201 cu. ft. Upright Freezer V2003RW3
Looking for a Woods upright freezer evaporator fan motor or a parts break down. i can find a universal fan motor but the blade is the wrong size and the rotation is in the wrong direction
  • 10 Answers
SOURCE: My woods upright freezer keeps
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Posted on Feb 07, 2009
  • 234 Answers
SOURCE: woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Posted on Jun 26, 2009
  • 1531 Answers
SOURCE: water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Posted on Sep 16, 2009
  • 4793 Answers
SOURCE: HOW TO DEFROST WOODS UPRIGHT FREEZER
just switch it off at the mains.DO NOT USE SCRAPERS OR STEAM.....(you can use car de icer but you will need to make sure its well ventilated)best left for 24hours....
Posted on Oct 03, 2010
aborcass
  • 2651 Answers
SOURCE: Can I transport a woods upright freezer in a
not the best way to do it, but if you must, just when oyou getit to its final destination leave standing up for at least 24 hrs before restoring power... you dont want oils from compresoor circulating through unit.. give it the full 24 hrs
Posted on Oct 13, 2010
I have a woods fridge
I am going to guess that it might be the fan and it is binding or has come loose and it hitting something.
Jul 13, 2014 | Woods Upright Freezer MU07W
Banging noise
Usually the condenser fan blade hitting on some part of the condenser or shroud.If you can access it, check the fan mountings, and blade for straightness.
Mar 23, 2014 | Woods 201 cu. ft. Upright Freezer V2003RW3
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
Need to replace evap motor for a whirlpool freezer
9abb6871-4eeb-4e17-b4b8-c4bfdafab542.jpgUnplug the refrigerator and remove the contents of the freezer. Then remove air tower and the inside back panel inside the back of the freezer. Disconnect the evaporator fan and replace with the new fan motor. W10189703 Evaporator Fan Motor I am here if you have questionsm Thanks Sea Breeze
Apr 20, 2013 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
My upright freezer is making a loud screaching noise something like a car's slipping fan belt makes in winter. It is still freezing but sounds like something is on the way out.
If you have the model number you posted under, you are looking at replacing the evaporator fan motor, which would be a part number 4309014 for that Maytag MQU1556A. It is located inside the freezer, behind the lower back wall.
Jun 22, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
135 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal De
Are you a Woods Freezer Expert? Answer questions, earn points and help others
