Question about Dryers
Dyer gets hot ,but tub will not turn. Could this be the belt and if so where can I get one and is it easy to install?
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 09, 2010
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Replace dryer belt
take off back of dryer....belt goes around tub and a pully on the motor....its fairly easy...when you get on there youll see...just make sure the tub is alligned correctly when you get it back together...turn the tub manually a cfew times before turning on and unplug before repairing......thanks and have a great day
Nov 08, 2009 | Amana NDE2330AY Electric Dryer
I need to know how to install the new belt
The following link explains how to install the belt on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is an easy process, but it may take some effort to get the belt on the pulley. It is designed for a tight fit in order for the belt to stay in place on the tub pulley with no play in it. There is no tensioner and you do not loosen any motor mounts. Just make sure you hold the belt tightly in place with your hands and turn the entire tub pulley (like a steering wheel) in a clock-wise direction. The belt will stay on after you turn the pulley far enough for it to grip and stay in place.
If you have not purchased a replacement belt yet, the part number for the model you have this listed under is 8181670.
If you have questions, please let me know. I hope this helps you.
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
How to install a belt for a frigidaire dyer how do i get the belt around the dyer
You must get the top up then you can easily remove the front then get that drum out clean everything oil everything and replace that belt. Very easy use my simple GUIDE
Apr 01, 2009 | Frigidaire GLER642A Electric Dryer
Gas dyer won't start, have to kick start it.
If your bearing,glides, and idler are all fine then your motor is gone.
You could apply some zoomoil to that motor but you will have to drill some access holes as the manufacturer does not provide any. For $150 bucks a pop I would try a $2 bottle of High temp zoomoil from ace hardware first.Use a 1/6th inch drill bit and do not hit the shaft. The bearing wells are on either side of the motor and you will have to take the drum out to get to the motor. To access the dryer innards open the door and remove the screws holding down the top. Get the top out yer way and remove the front. Get the drum out and clean out the dryer. Send me any folding money you find. LOL You may find enough change in the dryer to buy some oil. Zoomoil is use for HVAC. It is heat resistant and does not disapate. After filling each bearing work the motor by hand till it loosens up. Oil the idler check the slides and the rear bearing for wear.743d531.jpg
Mar 10, 2009 | Frigidaire Dryers
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
G E dryer
Open the service panel and look for a broken belt and does the motor spins. Let me know if you will need for further assistance. Good luck!
Sep 08, 2007 | Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
