Question about Sony KP-57WS510 57" Rear Projection HDTV
The picture on my kp57wv600 has bands of green light that curves and appears to be in 3-D. I have some experience in technical repair. What part should I order and where in the tv is the circuit board that I should remove the defective part(s) and then install the new part(s)?
  • 4,889 Answers
The problem you are experiencing is known as "convergence issue". It can be fixed by replacing the two STK convergence ICs. But before that did you try adjusting the convergence from the menu, by aligning the R,G,B crosshairs?
Posted on Nov 09, 2010
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
3 color curved band lines on my RCA tv.
Ur convergence is dead.U must know how to do soldering to fix this problems?Must replaced 2 STK convergence ICS,and some or all it resistors too.Tries websites Tv repair World.com,Tvrepairkits.com to do the reapair it ur self.The shop will cost U $300 for parts and labors.
Mar 20, 2010 | RCA R61WH76 61" HDTV
Screen has 3 lines at the top
you need to get a conversion done to correct this problem
Oct 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Removing green crt
More than likely you don't have to replace the CRT. Go to this blog for instructions for how to fix the most common problems.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
At the bottom of the page there are comments from users. There are several users that explain how to take off the front panel and where things are located. The model KP57WV600 is different than the pictures in the blog, including the fact that the order of the red, green, and blue adjusters are different.
If you try it and it's not successful and you still want to try to replace the CRT yourself, google KP57WV600 service manual and you can buy it for $9.99 and download it right away.
I wish you well.
May 03, 2008 | Sony KP-57WV600 57" Rear Projection...
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is Distorted, red/green/blue curves
you have bad convergenze this fault is common and need qualified person to change the STK ic's call repair man please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
