You want to choose the channel down button to set the HDTV backlight to an energy star qualified level because when setting it to a retail display level you will be locked out of adjusting the television's picture menu however you like. It will automatically revert back to the automatic retail display level or not allow you to make adjustments at all. However some people (usually seniors) prefer the retail display level, which is extremely bright. It uses a lot of energy and the television will not last as long on that setting either.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
