Question about Hunter 20404 The Bayport Bright Brass Ceiling Fan
Hunter Bayport Fan
Fan turns only at low spreed. Cannot reverse direction. Prior to this, it was working ok and I switched direction without stopping the fan. There was an ubusual buzz and now the fan can turn in only the one direction and a low speed.
  • jchirnitch Jun 16, 2008
    Thanks for the advice, but I am not sure which is the 'running' capacitor. There are two: one is a single 5mf cap and the other is a dual 5mf which has one end of each connected common.
    Genius:
  • 1,142 Answers
You need to get the running capacitor replaced then it will work fine and its a very low cost part.
Posted on Jun 16, 2008
How to reverse fan?
to change the fan from counterclockwise to clockwise get the fan going on hi. Hold the hi button while switching the wall switch from OFF to ON quickly. The fan will switch direction. To go from clockwise counterclockwise just hold down the low speed button until the fan switches direction. This makes no sense but it works only took 7 years to figure out.
Aug 10, 2014 | Hunter 27185 Remote Control
High and Medium don't work, only low
Check your capacitors to see if they're bad. That's the black box near the pull chain switch with wires going to the switch. If bad call 1-888-830-1326 Hunter parts.
2 wire part # 74132-01-000 ( probably not this one)
Other capacitor part # 74133-05-000 (probably this one)
Jun 02, 2013 | Hunter Dryers
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hi I need to know if I can switch the direction my hunter green Lasko fan is turning it is going clockwise and I would like to reverse it for the summer can't find a switch we've have it for...
Turn the fan off. Locate the reversing switch. It is on the base of the fan near the fan speed and light switches. if its not on the remote control. have a good day !!
If it does not have a revesing fan switch and its older, You may have to physically(with fan stopped)
Push blade in from end and twist blade for reverse air.
Jun 22, 2011 | Hunter Traditional Southwest 52" Ceiling...
The fan probably needs to be oiled? just stops
Does it slow down and stop after it has been running a little while (having had a chance to warm up?) Try this simple test with the fan cool and warmed up--- With the switch off, gently rotate the fan by hand. It should rotate very easily, and should coast to a stop not too abruptly. It should be about as free, and coast not quite as long, as the front wheel of a bicycle in good repair held off the ground. If it doesn't rotate freely, then yes, it needs oil. You might be able to get some oil on the bottom bearing without disassembly, so that's worth a try, especially if the fan is harder to turn warm than cool. If it's the same warm and cool, there's a good chance that there is hair wrapped around the shaft, and you will probably have to disassemble it to remove that - and while you are at it you can oil the top bearing. If it DOES rotate freely by hand, then you have a problem with the motor or the speed control, which is a whole other story.
Feb 24, 2010 | Hunter 20404 The Bayport Bright Brass...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Hunter 20404 The Bayport Bright Brass Ceiling Fan Logo
245 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
