Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I am looking for a usb/esata 1394 interface replacement part. Where can I find one?
  • 5,660 Answers
I find Mouser is one good place. There are others, not advertising for Mouser.
http://www.mouser.com/Interconnects/USB-Firewire-Connectors/_/N-55dbs/
Posted on Nov 09, 2010
  • 3 more comments
  • nanabren Nov 11, 2010
    amaynes...please let me know if you find one...I am searching for the same thing! thanks
  • joecoolvette
    joecoolvette Nov 11, 2010
    nanabren, did you look at the Mouser.com website?
  • amaynes Nov 11, 2010
    Seagate e-mailed me back and said that they do not make individual replacement parts. They suggested I check the warranty and send it back to them, but I need to get the files off it before I do that.
  • joecoolvette
    amaynes, what goes out on an external harddrive is the circuit board.
    A) Remove the Harddrive, install it in an external enclosure. The external enclosure has a USB 2.0 and eSata connections.
    B) Remove the Harddrive, install it in your computer, if your computer uses SATA harddrives.
    Removal procedures, two styles of Seagate FreeAgent Pro 500GB extermal harddrives,
    1) http://www.youtube.com/watch?v=NIs3Pz15O...
    2) http://www.youtube.com/watch?v=Y2vUMO2mG...
    The Harddrive is a SATA unit. It is a desktop sized harddrive.
    3.5 inches across in Width.
    (3 and a half inches)
    For an external enclosure you need a SATA 3.5 external enclosure.
    Here is one example,
    http://www.tigerdirect.com/applications/...
  • joecoolvette
    Edit: "Removal procedures, two styles of Seagate FreeAgent Pro 500GB extermal harddrives,", should be"Removal procedures, two styles of Seagate FreeAgent Pro 500GB exterNal harddrives,
Find firewire 1394
if you are looking for a firewire port on the laptop, i believe it does not have one.. your option for connection would be the USB 2.0 and eSata port located at the left and right side of the laptop
Nov 26, 2013 | Dell Latitude E4310 Laptop Computer (Intel...
CAN I USE MY HARD DISC WITH USB CONNECTION
Yes, you can. You'll need a little more hardware however. You can find "hard drive enclosures" at many computer stores, ebay and electronics stores. They look like these. In order to make this work, you need to determine the physical size and interface of the Samsung hard drive first. Most notebook drives are 2.5" and most desktop drives are 3.5" types (regardless of capacity). You'll need to find an enclosure for the drive size and interface type.
The Samsung drive is likely to be either and IDE type with a SATA (serial) or PATA (parallel) interface. Pictures of SATA cables are here, and PATA cables are here. You would select the enclosure depending on 2.5" or 3.5" size and SATA or PATA interface type. Lastly, would be to choose either a USB connection between the computer and enclosure, or an ESATA type. ESATA simply means External SATA. If your computer offers an ESATA jack on the front or rear panel, you might consider using it as it is much faster than USB. If you do not have an ESATA jack, stick with the USB type. All but the most oldest computers support USB 2.0 standard speeds, newer computers have a faster USB 3.0 speed (5Gbit/S) standard, but this hardware is fully backward compatible to the USB 2.0 & USB 1 speed (480Mbi/S) and hardware standards. If your computer has the original USB 1.x standrad speeds, you might consider purchasing a USB 2.0 or 3.0 expansion card as the USB 1.x standard is very slow (just 12 Mbit/S). Check these links for pictures of ESATA, USB 2.0 and USB 3.0 If you look closely, you can see the slight differences. USB 1.0 and USB 2.0 look identical.
Some enclosures will require / include a power adapter for the drive. Make sure you get what is required to get the drive to spin up properly. After your computer is up and running, connect the external drive to the USB jack and let the computer install drivers as needed; then use it as any other thumb drive etc. ESATA however may be different. In any case, follow the instructions included with the enclosure you purchased.
After copying good data, you might be able to format and scan the Samsung drive and map out the errant portions. Even still, I would not use the drive for important information or day to day uses. If you do, be sure to maintain frequent backups.
May 23, 2012 | Computers & Internet
My computer malfunctioned and I took out the hard drive to try and retrieve my files using a USB cable. I am stuck
Your hard drive has no USB port, it has a (seral) SATA 3 GB/sec interface, currently and
by far the most popular used on laptops, and also desktop computers. The SATA (serial advanced technology interface) 3 GB/Sec is version 2.0 of the SATA standard.
So, you'll need another laptop or desktop with a spare SATA 2.0 port, or a spare SAS (Serial
Attached SCSI) port, since SATA drive may be attached to SAS backplanes, as well as SATA backplanes. For a laptop, you may need to use the eSATA connector/cable
(see http://en.wikipedia.org/wiki/ESATA#eSATA for eSATA technical specs and a photo).
May 13, 2011 | Seagate MOMENTUS 7200.4 320GB SATA SATA...
Hi, i want to no, what is 1394 on motherboard and if the usb cable in the front write 1394, i install it like a regular usb cable?????
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to reformat a notebook laptop with no CD-driver?
Remove the hard-disk - it will usually connect via an IDE or SATA-compatible interface. You can then connect it to a computer (internally, or via eSata / USB / 1394 enclosure). You can then format it from that computer.
When you say no CD-driver, do you mean Driver or Drive?
if there's no CD drive, it should either have a floppy drive (in which case, any system book disk can re-format the HDD), or USB-booting capabilities.
If there's no driver, than a Windows 2000 / XP CD should be able reformat the disk - when you boot from it, it will load drivers off the CD. You don't need to install Windows normally, the recovery console can format disks.
A Windows 95/98/ME boot disk/CD will allow formatting, but only in FAT/FAT32 file systems (you will probably want NTFS, which 2000 and XP can create)
Sep 05, 2009 | Computers & Internet
I can't find out how I can put the DVI cable in my Acer Aspire X3200. There has to be an opening but I don't know how to open it.
HI! this is the specs of your video: Integrated NVIDIA® GeForce® 8200 graphics
or
Discrete NVIDIA® GeForce® 9300GE graphics
VGA and HDMI™ (High-Definition Multimedia Interface™) ports
TV tuner (select models only)
Aspire® X3200-B3530A: 22" LCD ..
this are the interface ports:
RJ-45 LAN
VGA
Headphones
Microphone
FireWire® (IEEE 1394)
Two PS/2®
Five audio
Nine USB 2.0 (five front, four back)
AX3200-ED5600A, AX3200-EF9100A only: DVI-D (graphics card), optical SPDIF
AX3200-EF9100A only: eSATA
AX3200-ED5600A, AX3200-U3792A only: RJ-11 modem
DVI-Digital - is a 24 pin digital DVI you can find that at the back or infront of your pc.. if there is a cover, try to push the door to open it..
Aug 12, 2009 | Acer Aspire X3200 PC Desktop
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Problem when connected to the e-sata port of two dif. computers
I think we a re talking about SMART technology, that is disk is telling you that something's wrong. If you have a guarantee, return it to reseller and ask for another one.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
119 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
