Question about Intermatic FF12HHC Energy Controls - In-Wall Timers 12 Hour Commercial With
10 year old timer will not shut off any more - Intermatic FF12HHC Energy Controls - In-Wall Timers 12 Hour Commercial With
It's broken.
I have a FF series countdown timer on a water heater circuit that's been used for past 4 years.
The FF and FD series timers are heavy duty, spring-wound countdown timers.
I expect 10 years is a good lifespan.
You can buy a new spring-wound countdown timer at Home Depot or Lowes, but new ones are lighter weight than the good ol' Intermatic.
Grainger sells the FF60 (60 minute, metal cover)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-6X546?Pid=search
Grainger shows the FD60 (60 minute, plastic)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-1XC27?Pid=search
Grainger Intermatic timers shows a lot of FF and FD timer choices:
http://www.grainger.com/Grainger/intermatic/ecatalog/N-1z0r56r
There are several pages of Intermatic timers:
FF5minute thru FF12hour
FD15minute thru FD60minute
Posted on Nov 09, 2010
I HAVE AN OLD BLACK AND DECKER 300 QUICK AND EASY IRON. DOES IT CONTAIN MERCURY?
I just looked up the manual. Unfortunately the best way to find out is to contact B&D.
This is from a recycling website.
Purpose of the Mercury: The reason that mercury tilt switches were widely used in irons and other appliances was because of the conductive and liquid-like properties of mercury. In a mercury tilt switch, as the switch is "tilted" the mercury flows with the switch to complete the circuit by conducting electricity and turning the appliance on or off. In irons the mercury switch controls an electronic shut-off timer, constantly resetting the timer when the iron is in motion. If a person leaves the iron turned on and motionless, the automatic shut-off timer turns the iron off after a certain amount of time, reducing the risk of a fire. If an iron falls, this feature will also prevent it from continuing to release heat potentially causing a burn or fire.
Potential Hazards: As long as the iron remains intact, there is a low probability that there would be a mercury release.
Recycling/Disposal: There is no easy way to identify whether or not an iron contains a mercury tilt switch. However, if the iron is more than 10 years old and it contains an automatic shut-off, consumers should assume that it contains a mercury switch and dispose of it properly.
Unfortunately, they keep referring to 10 years old, but it doesn't say when this information was written up. If it was written in say 2006, then it would be referring to 20 year old irons.
Jul 28, 2016 | Irons
What am I doing wrong?
If your Orbit system is 8-10 years old, the timer may be worn out. This is especially likely if the timer is electromechanical rather than digital.
Aug 01, 2014 | Orbit Sprinkler System Power Source...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I'm putting a new defrost timer in my jenn air refridgerator Model # JTB2688AEW, about 10 years old, the new timer has a setting for a 10 to 35 min cycle, the old timer just has the 10 hour info, but not...
Good day,
10/35 is fine. They don't always give the defrost period time. The original may have been a 10/30 or the same as the one you have. In either case the longer the better, since it allows more time for the water to drain out and prevent icing in the drain.
Jan 30, 2010 | Refrigerators
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
TV TURNS OFF AT DIFFERENT INTERVALS
How old is your TV?
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss. If the set is at least 10 years old this is typical and not worth repairing. If less, figure on replacing the flyback transformer.
Hope ya fix it!
Jan 06, 2008 | Samsung TX-R2735 27" TV
Intermatic FF12HHC Energy Controls - In-Wall Timers 12 Hour Commercial With Logo
227 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
