Question about HP LaserJet 4600dn Color Printer
How to service the HP 4600 with error code 51.2k
    Genius:
  • HP Expert
  • 1,325 Answers
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
    errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
    Aug 12, 2009 | HP LaserJet 4600 Printer
    ''HP Laserjet 4600, Error code 81 0180 E10 1 Error'' the printer does not work. please help !
    That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
    Jul 09, 2009 | HP LaserJet 4600dn Color Printer
    HP 4600 printer with error message 51.2M and loud noise when calibrating. Any solution?
    Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
    May 08, 2009 | HP LaserJet 4600 Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    2. Turn the printer off, and turn it on again.
    3. Perform a cold reset.
    4. If this message persists, contact an HP-authorized service or support provider.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    HP LaserJet 4600dn Color Printer Logo
    953 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
