My printer keep saying "
  • 1,218 Answers
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Posted on Nov 09, 2010
  • nitagoodatto
    nitagoodatto Oct 25, 2012
    Did the above, still starts to grab paper, I only print letters although some pdfs print in different size, then either "paper jam" or load letter tray"
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Put a new toner in, now says "paper jam"
There is little of paper in printer. Take the toner out and with very attention see, it must be in taht place, from where the paper going out, or that place from where taking paper, it can bee small paper.
Oct 12, 2012 | Oki Electric Industry Okidata Okidata...
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My printer keeps using the paper from the main tray, not the photo paper in the 4X6 tray. Where do I change this setting. I have it set to "photo" and 4X6 in the options. Is there a way to...
The option you are after can be found on the Print screen, if you click on the button saying Printer Preferences. Normally you will have multiple tabs, so click on the one saying Paper and on the Paper Tray option select Manual Feeder.
Nov 13, 2010 | HP Photosmart C6280 Printer
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
120 people viewed this question
jasbo
jasbo
