Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Netgear WGR614 router...not working...power was off and router not working now...could that be the problem...is there a reset ?
Mole72
  • 30 Answers
SOURCE: connection settings for a ps3 via netgear WGR614
you need to check your routers firewall setting by accessing your router through the pc and make sure your plug and play settings are enabled. all can be found on the router setup page. the playstation only requires you to enter the WPSK or WPA wireless encryption key to log on so the problem is usually with the router....hope this helps.
Posted on Dec 13, 2008
2Gigs
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
  • 58 Answers
SOURCE: Netgear WGR614 v6; where is the hard reset button,procedure to reset
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. )
Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  1. Release the button.
  2. Wait for the router to reboot.
  3. Log in with the default password.
If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  1. Unplug the router's power.
  2. Press and hold the reset button. While the button is held down, reconnect router's power.
  3. Continue to hold the reset button for 20 seconds after reconnecting the power.
  4. Wait for the router to reboot.
Posted on May 18, 2009
redhaze89
  • 854 Answers
SOURCE: My NetGear WGR614 v1 stops broadcasting and needs to be repowered
I suggest you do a firmware upgrade. But in doing this, you will loose the settings on your router. You have to reconnect all you devices on the new settings.
Please follow this steps:
2. Download this link ftp://downloads.netgear.com/files /wgr614v1_1400.zip
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Setting the router:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 18, 2009
  • 16 Answers
SOURCE: My power light on my Netgear WGR614 wireless
Maybe you had a power surge.
The reset button does nothing with the router powered off, basically you hold the reset button in for 30 seconds with the router powered on. Following this you will need to set up the router again as all settings will be reset to factory defaults, from the sounds of it though the router may be dead.
Another reset method is as follows;
1. With the router powered off hold in the reset button,
2. Keep the reset button in, power on the router, wait 30 seconds,
3. Keep the reset button in, power off the router, wait 30 second,
4. Release the reset button.
Did you have wireless disabled?
If you have access to a multimeter check the PSU is working correctly.
Posted on Feb 04, 2010
Log in wireless network Netgear wgr614 v9
The default address for netgear routers is : 192.168.1.1
So just open a browser, type 192.168.1.1 and hit go. It will ask for a user name and password. Default UN : admin PW: password
If that doesn't work, check the bottom part of your router for the username and password. If still not working, the login might be changed. You can reset the router to factory settings by pressing and holding the small reset button at the back of the router for 10-15 seconds while the power is on. You can use a pen or a pin to reset it. Wait for a minute and try it again.
Hope that works,
Regards.
Sep 26, 2011 | NetGear WGR614 Wireless Router
We are using WGR614 V8 Netgear Router it was working fine but one day after putting power switch on front panel of Router Power indicator LED and wireless LED are not glowing but Test LED, internet LED and...
no it never needs a hard ware repair... doing a hard reset for the router will help... press and hold the reset button on the router for 10 to secs using a paper clip or any safety pin.... reconfigure the router when reset is done completely...
Dec 13, 2010 | NetGear WGR614 Wireless Router
Their is a code that i dont remember and i dont know how to get it
Reset the router:
  1. Push the "Default Reset" button on the back of the Netgear WGR614-V6. The button is located on the back of the unit, to the left of the external antenna. You may need to use a pin or the tip of a pencil to access the button.
  2. 2
    Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on. This takes approximately ten seconds.
  3. 3
    Let go of the button. The Netgear WGR614-V6 shuts off and turns back on. Allow several seconds for this process to complete.
  4. 4
    Log into the router using the default password by opening a Web browser and navigating to the address "192.168.1.1." Enter the password "password" to log in.
Read more: How to Reset the Password for Netgear WGR614-V6 ' eHow.com http://www.ehow.com/how_6500350_reset-password-netgear-wgr614_v6.html#ixzz16oThLs5P
Nov 30, 2010 | NetGear WGR614 Wireless Router
Network Key for netgear wgr614
Hi, taffy_man, the network key is something you configure yourself. If you dont know it you have to RESET the router to the factory defaults.
Take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type www.routerlogin.com into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
If that doesnt work do the same thing but first disconnect the power cable. Then while pressing the reset button THEN connect the power cable again but keep the reset button for 10 secons and then go to the routerlogin.com or (192.168.1.1) and do what I wrote above. Then you will have to reconfigure your settings. I hope this helps.
Apr 29, 2010 | NetGear WGR614 Wireless Router
My power light on my Netgear WGR614 wireless router keeps blinking & will not allow me access to the internet.I have unpluged it, pressed the reset button & the light keeps blinking.Any thoughts?
Jan 27, 2010 | NetGear WGR614 Router
Cannot reset my password on my router made by Netgear can you help Netgear router WGR614
Power up the Netgear and press the pinhole RESET button on the back of the Netgear until all the LEDs flash, then release the RESET button.
The Netgear is now restored to the factory default settings.
Dec 26, 2009 | NetGear WGR614 Wireless Router
May 18, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 Power light goes off.
I understad that you need to powercycle the router for it to work. In this case, please note that this indicates failure with the router hardware. The only thing you can do now is upgrade the firmware on the router. You may check for firmware updates by visiting the site below:
http://kb.netgear.com/app/products/family/a_id/1296
After uploading the firmware on the router, reset the router and reconfigure it.
If the issue persists ten the best bet for the router is to either get it replaced or trash it.
Anand
Netgear Tech Support
Jan 10, 2009 | NetGear WGR614 Wireless Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
159 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
