Question about Acer Aspire 5100 Notebook
Keeps going nto hiberntion
Help! My computer is plugged into ac adaptor but it also says no device and blinks constantly.
  • Erinleta Jun 17, 2008
    Thank you so much!
  • Erinleta Jun 21, 2008
    Thank you, I think you.re right
    Scholar:
  • 111 Answers
Sounds like your adapter might be faulty, can you try another one to test?
Posted on Jun 16, 2008
MAXTOR Personal Storage 3200 - LED light rapid blinking
Many experts beleave you got a bad AC adaptor the plugs into the wall. My findings are the following.
If you hear the drive spin up but does not show up on your computer then you got a bad controller board inside the case of that hard drive. The fix take the drive out of the enclosure and put it into another enclosure or simply install it into your computer.
I have videos on a WD mybook witch is not the same model or manufacture but still helps some people figure out what to do. Please be considerate i mean the videos are dark but you can still make out on whats going on.
http://www.fixya.com/support/r3574054-external_usb_hard_drive_data_recovery
Now you can try a AC adpator for this unit some ac adaptors do fail but in most cases its the little usb to sata connector inside.
good luck with this and please do be considerate and rate.
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Doesn't turn on unless plugged into ac adaptor
You may have to replace the battery or it's possible there's a short circuit on the battery line that's why it's not charging.
May 06, 2009 | Computers & Internet
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
My sansa e250 keeps connecting and disconnecting from the computer. every time i plug it into the computer, it keeps saying that it's connected and disconnected to the computer. this switches repeatidly...
If it is flashing constantly, go into Start --> Control Panel --> Printers/Other Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
SimpleTech 320GB Hard Drive- unable to detect the device
My simpletech external did the same thing. I used another AC Adapter from another External drive and Viola...it works great. I think the adapter came defective.
Jan 01, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
