Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
On off light blinks and the channel and volume button stay illuminated after i put new batteries in
    Genius:
  • 1,672 Answers
The electro touch that makes to control the VOLUME is stuck! Open ur remote, and look at the board where the VOLUME button is located, u will see a BLACK electro pad have shorted that part! Clean it up by wiping w/ clean cloth, but be carefull not to damage the BOARD black electro terminal! Buy any LiQUiD ELECTRO COATiNG, and put on that VOLUME button and let it DRY! That might help u out!
Posted on Nov 09, 2010
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Calibrate wii remote
What to do:
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure must be followed for each additional Wii Remote added to the system.
Sep 14, 2013 | Nintendo Wii Console
How to reporgram my tV's remote to the Tv again
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 09, 2012 | RCA Televison & Video
My LG Optimus T froze and then the four buttons started blinking. I took out the battery and put it back in and it stayed on the LG screen while the four lights continued to blink.
ur battery is dead!!! even if u have a new phone......just plug in ur phone and take out ur battery and if it still duz it that means u killed the battery.i hope this helps a little......info by MR.GIZMO
Feb 01, 2011 | LG Cell Phones
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Remote not working on TV
Try programming with Code Search:
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
How do i!
make sure the batteries are good and installed correctly. turn on device(manually) press and hold (setup) button until the red indicator stays on. then release the set up button. press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit. press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track. now press and release the mute button to lock in the code.
Jan 13, 2007 | GE RM24912 Universal Remote Control
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
