Question about Gateway M465-E Notebook
I have a gateway M465-E it power up but it has no battery indicator when charging or just on also i have no screen light up i have a spare known good back half of the same model when i connect it to the laptop the known good screen as does not light i think my problem is on the MB but wanted to send it past you for your opinion. the Mb is a MA6MB0057 ifthat is needed by you. my idea is that the ATI 128 chip on board is bad.
  • 386 Answers
Hi Good day!!! Did you try checking the RAM of your laptop? try to remove it clean it same as the memory slot and then re insert it see if your display will light up.. if still not reply to me
Posted on Nov 09, 2010
Gateway M465-E Notebook hangs after booting
try removing and testing each memory separately
or try fix start up
Dec 16, 2013 | Gateway M465-E Notebook
M465-e has flashing blue light wont startup
Try removing the battery and disconnecting the power for a minute or so. Then re-install the battery and power cord and try booting it up again. If that doesn't work I'm afraid it's probably an issue with the motherboard.
If in the unfortunate event the motherboard needs to be replaced, here are the instructions:
http://www.ehow.com/how_7498700_remove-motherboard-gateway-m465e-laptop.html
Looks like boards range between $100 - $200
If it's not something you want to tackle yourself, expect labor to be about $100. Consider the age of the laptop and the cost of about $200-$300...some newer laptops can be had for that amount. (Especially with Black Friday sales going on.) Check microcenter.com
Nov 24, 2012 | Gateway M465-E Notebook
Power light flashes put unit doesn't power on
Laptop is having a power problem. Problem is either from the Adapter or battery (optional). Or the power part on the mother board has a shot.
Jan 26, 2012 | Gateway M465-E Notebook
The power supply is putting our 21v no load no lights on batt. or power supply
I would say that your power supply died on you and in process drained your battery. So you probably need new one.If you can check that with other to be sure.Or your battery went bad and now is making mess. For this to check, take out battery and try to star without it. Good luck!
Nov 09, 2010 | Gateway M465-E Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Have a gateway M465-E with power issues. Low
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 26, 2009 | Gateway M465-E Notebook
Power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Nov 15, 2009 | Gateway M465-E Notebook
Gateway M465-e Wont Start
Is your laptop receiving charge from the power supply. If not your power supply is bad. If yes.. The power mosfet of your laptop need to replace including a fuse.
Jul 26, 2009 | Gateway Computers & Internet
M465-E will not turn on
Simply your RAM or mother board is faulty. Replacing RAM is cheap but repairing Mother board modules is an expensive affair.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Gateway M465-E Notebook
Gateway M465-e
replace the cmos battery
Mar 18, 2009 | Gateway M465-E Notebook
Gateway M465-E Notebook Logo
152 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
