Question about Sharp Comfort Touch AF-R120EX Air Conditioner
My ac was serviced and 8.8 shows on the display and its not cooling, every button i pree either turns it off or on. how do i fix that?
  • 81 Answers
Does it work on heating ? when its on make sure you wait for a minute for the fan the start. when you say not cooling is it just blowing room temp air around or no fan nothing?
Posted on Nov 09, 2010
My carrier model number 42QH12-h wont turn on after cleaning and the temperature display showing number 8
Try resetting the AC by flipping the breaker for a few mins and see if that clears the error. If you need more questions for your Air Conditioning Repair needs, check us out online
Jun 30, 2017 | Carrier Heating & Cooling
Error code E000003-0002 canon irc 2880i
you can=
Clear the error code in service mode
but I would inspect the following first !!!!!!!!!!!!!!!SERVICE MODE
press Additional Functions Key (once)
press #2 & 8 key at the same time (release both)
then press Additional Functions Key again (release it)COPIER>FUNCTION>CLEARERR Clears error codes.
(Cleared error codes: E000, E001, E002, E003)
Operation method
1) Select this item, and press the OK key.
2) Turn the main power OFF/ON
E003 with a sub code of 0002, which indicates that the machine detected an abnormally low temperature when the fixing heater is turned on.
Check the temperature in service mode and see if the readings for the sub thermistors under Display for FIX-E and FIX-E2 would bounce back an forth between 0 and 36 degrees repeatedly.
1-Faulty Fixing Film Unit
2-DC Controller and DC Driver
NOTE:
Before replacing such things as, the entire Fixing unit, the DC Driver PCB, AC Driver PCB, and DCON; check SW3 and it's right door actuator.
In some cases SW3 has been found to also cause E003-0002 codes (also sub code 0000).
SW3 is the Fixing unit's AC interlock switch. Sometimes the right door actuator will be bent and not fully press SW3 when the right door is closed. SW3 is a button switch located right above some of the Fixing unit's rear frame connections.
SW3 has been found to show signs of wear and have carbon build up inside it. If the right door actuator is straight and making good contact , inspect SW3 and it's AC connections. If any flaws are found after inspecting SW3, replace it. SW3's part number is, FM2-9427-000.
The image below is for reference purposes only, it points out SW3 and it's right door actuator.
Oct 17, 2016 | Canon Office Equipment & Supplies
I10 engine heats up but does not display on the dashboard. In fact the newly services ac also stops cooling at times
Take it back the garage that done the AC as they have not checked the cooling fans are operating as when the AC is turned on the fan should run straight away .Sounds like your garage need to employ skilled mechanics and not unqualified chancers ,remember the old adage if you only pay peanuts you only get monkeys .so please print this off and show it to the garage .
Jul 13, 2015 | AC Cars & Trucks
2003 Lincoln Navigator, I cleaned my center console panel (AC/Heater control knobs) because of sticking buttons now the buttons (Auto, Off, Dual, etc) does turn on or off AC/Heat, nor does the display...
shudnt hav done that-u caused corrosion--now u need to take um out and see if their salvagable--getta haynes manual or sec629-ur local library
Nov 20, 2013 | Lincoln Cars & Trucks
Flashing cf after carrier ac turns off
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
Mar 12, 2012 | Carrier Heating & Cooling
How do you turn off the service interval bleeper on my 2007 vw polo
Service reset
1. Turn the ignition OFF.
2. Press and hold the reset button [1] (see the above picture).
3. Turn the ignition ON.
4. "SERVICE" appears on the display.
5. Release the button [1].
6. Turn the button to the right.
7. The service indicator shows: "---".
8. Turn the ignition OFF.
9. The system is reset.
Jul 16, 2011 | 2001 Volkswagen Golf
How can you reset the service light on a vauxhall corsa cdti on a 54 plate
Service reset
Important note: Proceed exactly as follows; otherwise the reset system will go into the locked position and special tools are required to unlock it (Tech 2 tester).
3. After 3 seconds the "Distance till service" appears on the display, "InSP 0".
4. Press and hold the brake pedal.
5. Note: Ensure the button [1] is still pressed.
6. Turn the ignition ON.
7. The display shows: "InSP----".
8. After turning the ignition ON, wait for the service message to change and keep the reset button pressed for at least 3 seconds.
9. Release the brake pedal and reset button at the same time.
10. Wait for 10 seconds, until the display shows: "InSP XX,000 km".
11. The system is reset.
Jul 15, 2011 | Volkswagen New Passat Cars & Trucks
As the VAT has changed in the UK to 15% instead of 17.5% i need to change this on my Casio calculator. I have a Casio MJ 100. Please help me!
Hi. Switch on using the Ac button
Press the TaxSet button - and hold for 2/3 seconds
You will be show either the current tax held or zero
Type in the tax you want ie 15
Now press the taxSet button.
To verify its worked prees Ac button then press the Tax+ button is should now show you 15%. Hope this helps.
Apr 30, 2009 | Casio SL-100 Calculator
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
90 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
