Question about Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB - 102608-056-B - Biscuit
We have a Maax Living 6636 Hydromax tub. The display reads no H2O even when the tub is full. We've adjusted the water level sensor but the problem persists.
  • 659 Answers
SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Posted on Aug 19, 2009
  • 80 Answers
SOURCE: error e006 maax tub water
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
  • 10 Answers
SOURCE: I don't know how to work my Maax hydromax double
Try to downlaod the manual from the maax website. Hopefully you can find the model #. Look around in the pump acess area for it. If you cant find it try to match it up with a current model image from the website or do an online image search. All major companies offer there liteture available online somewhere, maybe under a seperate tab, on the product page.
If this does't help you should post again and be more specific i.e. what can't you get to work? Tubs these days have many different feaatures. Also model # and estimate what year it may be.
Wish I could have been of more help.
Sincerely, T. Wood C&F Enterprises a plumbing contractor.
Posted on Oct 08, 2009
tunde007
  • 2382 Answers
SOURCE: Maax bathtub (I believe Saturna)
Hi, the from your explanation it's quite obvious that the controller is faulty and needs to be replaced. You can try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada.
Posted on Mar 01, 2011
Maxx hydromax tub -- I notice other postings with the same questions: 1) need owner's manual and 2) when I fill tub I get error message "no h2o" then motor shuts down within a few seconds. What to do?
water sensor in the pump is faulty ( wires disconnected or program board faulty)
call in a tub technician for a diagnosis and quote to fix
Jun 25, 2017 | Washing Machines
Control Panel
Most topside panels are just stuck on the top of the tub with a double sided tape.
Sometimes it can be held into place with a nut on the underside that must be unthreaded to remove the top panel.
Rod
US Parts Center
888-521-6183
Mar 29, 2014 | Maax Living 7242 Hydromax Whirlpool -...
What is the unscrewing tool for the lights
On the backside of the light lens is where the light bulb is changed. There is usually a white fitting that houses the lamp in a socket fitting.
Get to the backside of light fitting and you can change the bulb.
Rod
US Parts Center
Nov 27, 2013 | Maax Living 6636 Hydromax Whirlpool -...
I have a maax hydromax tub and the temp. control needs replaced where can i buy one
Not as easily done as you would expect. What is the Model number of the Control Box under the bathtub?
We need to know that before we can match up the sensor for you.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 | Maax Home
Where is the filter located on a maax whirlpool drop-in tub
As far as I know you do know have a filter. I have read my instruction manual and it does not mention a filter at all. I have the Topaz 6036. To clean it you are to fill your tub with water and put in dishwasher detergent and let the tub run for a few minutes. You can also add a small amount of bleach.
Dec 17, 2011 | MAAX PALACE 6-JET HYDROMAX DROP-IN BATHTUB...
E06 on newly installed maax calla
E06 is the water sensor, The tub will not operater if there is not enough water in it. If the water level is not the problem, it is most likely a bad water level sensor.
Jun 03, 2009 | Maax Calla 6042 Bathtub - 101058-000
Error e006 maax tub water level sensor
May 09, 2009 | Maax Calla 6042 Bathtub - 101058-000
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Dec 16, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB - 102608-056-B - Biscuit Logo
294 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
