Question about Pride Wrangler 4 Wheel Heavy Duty Scooter
Wrangle is fully charged, powers up ok, when trying to move you can hear the brake release but will not move in either direction.
I can't get my scooter to freewheel when both levers, one on each motor, are in the down position. Wont move under its own power either. Batteries are fully charged.
Posted on Oct 22, 2011
  • 692 Answers
Bqsmc Dang scooters are a mess to troubleshoot because there are so many things that have to work to make it run. Well the brake energizing means you are getting power to the brake but the problem could be the throttle pot, or the speed control pot or the motor itself. To eliminate the motor disconnect the motor connector from the wiring harness and with two jumper wires supply 12 volts to the red and black wires in the plug. (you can jumper from one of your batteries) and the brake wires (2 smaller black wires) you might try jumping the brake first to see if the 12 volts will energize it. If not you will have to supply 24 volts the brake to energize it. If you get the brake energized then supply voltage to the motor leads and it should turn (Block the rear wheels off the ground) If it doesn't then bad motor. If it turns then reconnect the connectors. And then order a speed pot and throttle pot and replace both in the console Hope this helps
Posted on Nov 09, 2010
Kia grandsportage
IF IT HAS REVERSE OK 3,4,5 OK 1-2 SHIFT FORK IS SUSPECT INTERNAL
Oct 05, 2017 | Ford Cars & Trucks
Started saw chain moved , now it won't.
Sounds like the chain brake has activated, pull the hand guard fully back to the top handle until you hear the click of the brake loading.
Feb 11, 2011 | Poulan 18" Wild Thing Chainsaw
Ihave a strider st4 and the power gauge goes down fster than any other scooters
hi, OK first check the charger, is it charging correctly please confirm this if possible by borrowing a charger, check the charging port, it is a loose fitting , do you always get a green light on the charger ?, if not check the connection at the charging port.
if after use say greater than 2 miles , the batteries charge up within a couple of hours, that points to your batteries losing the ability to take a charge, now first check the terminal connections to the batteries, are they clean and tight.
Check the brake mounted on the side of the motor, can you hear a click when powering backwards or forward , it may be advisable to get the wheels off the ground, please take care when doing this.
If the brake has become lazy it may not be releasing 100% , moving the wheels around when slight , (just so yo can hear the click, it may be very faint), power applied will test this, again please take care when doing this test
OK so the batteries are charging up, then sadly 95% sure it your batteries, that need replacing. the other 5% being a faulty controller, dodgy motor, but this is very rare.
Please leave feedback if the suggestions help.
Regards GeWiz.
Feb 02, 2011 | Electric Mobility 4 Wheel Heavy Duty...
Hi, Just replaced two batteries. Chair powers on but I just hear a click sound when I push the button to move chair. please help. thanks.
The fact that you just replaced the batteries indicates a battery problem that has been solved. Please make sure the new batteries are fully charged. The fact that the power wheelchair powers on is an indicator that the VSI controller (joystick) is working. When you move the joystick forward you will hear a click sound from the motors and electromagnetic brakes. The click is the brake being released by the electromagnetic solenoid. If you have a flash code on the controller and the chair does not move you can look up the flash code using the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This motor/brake problem is typical for the Aspire and can usually be traced to the large connector at the back of the power chair. Pull out to disconnect the 8 pin connector and disconnect the 3 pin molex plug. Inspect and clean with electronic contact cleaner the silver pins until they are shiny. Spray clean the plugs. Work the plug in and out to clean the inner contacts. If the chair now runs you have traced the problem to the main harness receptacle and the VSI controller plug. The only cost effective repair of the the main harness receptacle is to replace it. The VSI plug is can be cleaned several times before it needs to replaced or the controller rebuilt.
If you need to replace a motor/brake assembly you need to contact a qualified technician who can troubleshoot further with a PP1 programmer to read the fault code history log. The technician will also have a digital voltmeter to verify your motor/brake problem. In my experience, the motor/brakes can last up to 3 years depending on use. The wiring harnesses at the rear location are easily hit and are usually more problematic because of their location, collecting dirt, moisture, and corrosion. Hope this helps,
Nov 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
I have a s320 auto and the gear lever is difficult to move from park to drive this has started a couple of days ago any advice
first get in to the car close the doors and shutters switch off radio and a/c then witch on ignition, when you press the brake can you hear clicking sound in shift liver, release brake and do press it again and listen, if you can clearly hear click sound, it's mean brake light switch is OK. could be faulty safety release lock in shift liver control, if can't hear clicking sound in shift liver first check the brake light switch.
Nov 19, 2010 | Mercedes-Benz S-Class Cars & Trucks
My four wheel golden electic scooter is fully charged but went from fully operational to just clicking and not moving at all. Can you help?
Hi. I have had this problem on many machines. It is normally a stuck brush in the motor. This stops the motor from going. The click you can hear is probably the brake solenoid releasing.
Can also be a faulty connector in the motor or battery leads.
Good luck. Neil.
Jun 09, 2010 | Golden Technologies Avenger 4 Wheel...
Looking for a User Manual for a Days Medical Strider Mini 4 Mobility Scooter. Battery might be at fault.........battery fully charged but within fifteen minutes charge lost.
Cant help with the manual but the solution to your problem will probably be duff batteries. This is most likely but it could lie with a number of other things. May be charger but probably unlikely. If not batteries, I think this may be the electromagnetic brake not releasing properly and dragging the batteries down. You can usually smell if they are not releasing as they get VERY hot and smell similar to a burnt clutch on a car. The brake is attached to the end of the motor. If you can hear a click from the brake when the throttle is pressed, it might be ok (although it should really be tested with a multimeter for resistance and voltage as the fault could lie in the wiring loom). Also, if its not releasing correctly, i may have turned a shade of blue due to heat build up. Other problems could be high resistance within the motor or transaxle. Would need to perform a Motor Draw test to determine which, if any, of these are at fault.
Mar 14, 2010 | Health & Beauty
AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Jan 11, 2010 | Pride Mobility Products Go-Go Elite...
Jazzy 1113 will not operate!
The click you hear when you activiate the joystick is the electric solenoid on the automatic brakes going on, and then off when you push then release the joystick. This is normal. If it isn't moving, check to see if the free-wheel levers are in gear or in neutral. If you can push the chair, you are in neutral and activating the joystick will just release the brake and run the motors. Turn the two levers to the drive position and then it should take you where you want to go.
You can go to Pride Mobility's website to download an owners manual for your chair here
http://www.pridemobility.com/jazzy/1113ats.asp
Good luck.
Jul 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Wrangler 4 Wheel Heavy Duty Scooter  Logo
157 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
