Question about HP Color LaserJet 2600n Printer
Left side of the print is acting like it is burning and looks terrible
  • HP Master
  • 7,733 Answers
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
Ok,left blinker works fine,its only when i use my right turn signal is when my lights act like my flashers is on?
You most likely have a bulb on the right side that is burned out. Put the left turn signal on and walk around your vehicle to see which ones light up then switch it to the right side and do the same thing at this point you should be able to tell which bulb is not functioning proprly.
Mar 14, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
Color in printed pictures is terrible! All HP
try going into your printers properties and look for a print quality tab. One of the tabs will allow you to change your print style on pictures. Or the HP software that came with the printer should allow you to modify the print quality.
Jul 06, 2010 | HP Photosmart 3210 Printer
I have a printing problem, the left side of page hardley prints.
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300
Jun 14, 2010 | Samsung CLP 300 Laser Printer
I am pretty sure there is a relay bad on my focus for my signals. the left turn signal flashes faster than the right. Which one do i change?
Howdy,
First look for a burned out bulb on the side that flashes faster. Look carefully. Go to the right side that flashes normal and see how many bulbs flash front side and rear. then turn to left side and look, you may find one bulb burned out.
Good Luck !!!!!!!!!!
May 10, 2010 | 2000 Ford Focus
Samsung 1640 printing problem
A number of things! First did you ever clean out the paper path? Run out and buy paper path cleaner and run it 10 times. Try printing again and see if it corrects the problem. If it still acts like that, then you would need to change out the toner (if supected of defects or if empty) or change out the led inside the printer which you would need a repair manual to disngage and replace it.
Mar 05, 2010 | Samsung CLP 315 Laser Printer
My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Poor quality impression
I am supprised your repairman couldnt fix this, either the hammer is binding or the V 1 resistor on the logic board needs adjusted I do this repair in my shop quite often.
Jan 18, 2008 | Swintec 7040 Typewriter
HP Color LaserJet 2600n Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
