Question about Dirt Devil Vacuums
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
    President:
  • 1,673 Answers
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Posted on Jun 17, 2008
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
My vacuum is not working properly, it is not sucking any dirt. What should i do? where should i take it to fix it. i already checked the hose and it is not clogged
Remove hose an look down into tube that connects hose. There's a small elbow on the bottom that clogs easily. (Mine has multiple times - dog hair)
Mar 21, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil doesn't **** up air from either way. I changed the filter and I'm still having this problem. It sounds normal so I have no clue what can it be.
follow the hose to where it conect to the elbow that to connects to the vacuum unscrew the two phillips screws holding it on and i bet it has aclog
Dec 12, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
May 01, 2010 | Fantom Vacums XT450K Upright Vacuum
Will not **** up dirt when vacuuming but the attachment hose does pick up dirt.
You have a clogged hose my friend. Clear clog and start sucking up the dirt again
Dec 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a clog inthe main tubing. It is from a
slide your garden hose up the length of the tubing after laying the tubing flat in a straight line. If the blockage is in the hose this will detect it. It may be necessary to hook the blockage out with a length of wire.
Sep 04, 2009 | Electrolux Vacuums
The vacuum cleaner does not pick up anything from carpet. It does not even pick up pieces of thread laying on carpet. On tile floors it blows dirt away instead of picking it up. I've tried all the settings...
Sounds like there is a clog..
Usually its in the hose - look closely.. Stretch the hose out straight and look in there good..
Or a clog could be in the vac close to where the hose conects to the vac on either end..
This is most case scenario with these types of vacs..
I hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Hoover U5269910 Bagless Upright Vacuum
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Dec 04, 2008 | Dirt Devil Featherlight Bagless Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
163 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
