Question about Delta & Single Handle Shower Faucet
Need to make the single handle faucet produce hotter water
3 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: Need to fix a leaking delta shower faucet and need
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Posted on Mar 31, 2010
  • 349 Answers
SOURCE: & Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
Posted on May 20, 2010
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Can I adjust the hot water temp if I have a Posi-temp faucet?
should have a gearlike part under handle that can be adjusted so as to allow the handle to rotate to more hotter (left) or warmer
Dec 08, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The handle stops mid way between hot and cold. The water gets barely lukewarm.
Have you tried adjusting the temp control setting behind the handle. Remove handle and mark the dial or remember where it located and slide it out of place so you can move it counter clock wise maybe a 1/4" turn and put handle on and turn faucet on and check for hotter water.
It is a anti scald valve and it's preset to a certain temperture for safety.
Oct 05, 2010 | Delta & Single Handle Shower Faucet
May 17, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Need to increase the water temperature moen 270/3371
Remove handle, now you should see two white plastic pieces one slid inside the other. The inside piece should look like a gear. If you slide it out and rotate to the left a couple of teeth this will allow for handle to advance farther and in turn give you hotter water.
Jan 30, 2010 | Moen TL3450/3600/3371 Kingsley Handle Tub...
THE SCALDGUARD ALLOWS VERY LITTLE HOT WATER HOW TO CHANGE TO BEABLE TO FILL TUB I HAVE A DELTA#T13220 I CAN'T THE HANDLE OF EITHER
You probably need to adjust the faucet to give you hotter water.
The other problem can be low water pressure... if your cold water pressure is low or there is a restriction in the line, it willl also restrict the hot water flow.
Follow these instructions to pull the whole valve assembly out and check the water flow of the cold water with out anything in the valve body. This will tell you if the problem is in the piping of the valve.
http://www.everyfaucet.com/Delta-T13220-DLT2970.html
Page down to near the bottom and look for the PDF attachments. They will give you the details you need to take the faucer apart and amke the neccesary ajustments.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
291 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
