Question about Quasar HQ2101SH Air Conditioner
Quasar unit trips circuit breaker, still cools when it stays running
    Novelist:
    Champion:
  • 230 Answers
This is not very much information to go on, but I will say that it sounds like one of 2 basic problems.
1) The compressor is pulling high amps and should be replaced
2) It may be a weak breaker that trips before the proper amp load is reached.
Posted on Jun 16, 2008
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
I have a Quick Cool (59516.501) which just started tripping the 20 A circuit breaker. I replaced the circuit breaker. Unit still trips the circuit breaker.
you will need to access the unit and look for burnt/shorted wires on/at compressor. if not then the compressor is locked down/shorted and will need replaced Tim
May 29, 2011 | Dometic Rooftop RV Air Conditioner
The circuit breaker is tripped after the ac is turned on.
Either the circuit beaker is overloaded (check to make sure no other electrical appliances are on that same circuit) or the unit draws more amperage than the what the circuit breaker can handle,. Or the there is an electrical short in the AC unit. Also, check the receptacle that the unit's cord is plugged into for damage, loose wire or broken or cracked socket.
Those are the things you start troubleshooting first.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | Quasar HQ2141RH Air Conditioner
Is the red reset button on a garbage disposal supposed to stay 'pushed' after pressing it?
Yes. It's a circuit breaker that only pops out when it has tripped. If it won't stay in, then the problem that made it pop out is still present. This could be due to overheating (in which case it won't stay in until it cools down) or a short circuit (in which case it won't stay in until the short circuit has been removed). Wait 30 minutes (to give it plenty of time to cool down) and try again. If it still won't stay in, you have problem. By the way, if the unit is jammed, the breaker pops out because the unit quickly overheats. Good luck, Al K
Oct 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Fan works, but if A/C turned on, trips breaker within a few minut
You need to verify if the problem is the unit or the breaker.  To do this, you will need to measure the current it is pulling from the power source.
If the unit is pulling too much current, then the unit is the problem.  If the unit is pulling as much or less than its rated current draw, then the circuit breaker is worn out.
The units WILL pull more power when hot outside.  It should not trip a breaker unless something is wrong with either the unit or the breaker.
A current draw test will tell you for sure.
If it's not the breaker, then it's probably low refigerant causing the issue.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Quasar HQ2101SH Air Conditioner Logo
67 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
