Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Hi, I am trying to install D-Link router WBR-1310 but getting the error code 101 IP address not maching. What do you suggest?
  • D-Link Master
  • 7,733 Answers
Use the PING command to test the communication between the computer and the gateway.
Goto Start > Run and enter COMMAND.
From the Command Prompt, enter PING 192.168.0.1.
The gateway should reply.
Verify that the residential gateway is getting power. With the broadband modem connected to the WAN port on the gateway, you should have a soild WAN link light. You should use the same cable that connected the modem to the PC to connect the modem to the WAN port on the gateway. Any port on the gateway that has a computer connected to it should have the corresponding LAN link light lit. If you do not get the appropriate link lights, try using different cables.
onfigure browser/Internet Options
Step 1 Go to Start > Settings > Control Panel.
Step 2 Double-click the Internet Options icon.
Step 3 On the Security tab click Restore the default security level.
Step 4 Click the Connection tab and set the dial-up option to Never Dial a Connection.
Step 5 Click LAN Settings. Nothing should be checked. If anything is checked, uncheck it. Click OK.
Step 6 Click the Advanced tab and then click Restore these settings to their defaults.
Step 7 Click OK.
Step 1 Turn the Cable/DSL modem off.
Step 2 Turn the D-Link router off.
Step 3 Wait 60 seconds.
Step 4 Turn the cable/DSL modem back on and wait until all the lights are steady.
Step 5 Turn the D-Link router on.
Most routers and modems do not have an on/off switch. Simply unplug the power. Unplugging the power will not reset (reset back to default settings) the unit.
Posted on Nov 09, 2010
I am trying to setup my router model wbr 1310, with password protection. but when i come to the ip address and static ip address i cant go any further, help
Hi, There. You should try to reset the router. There's a small hole in the back that you must press with a needle or something similar for about 30 seconds. After all lights turn off and back on, your password should be the factory's original, usually Admin as username and no password.
Good Luck!
Apr 30, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Im useing an ethernet cord with my D-Link router WBR-1310 and it still wont connect
hi
i am techbuddies from fixya group and i wont to try to resolve your issue .
first of all we need to check that whether the router is talking to the computer or not and u can do this by
start> run > cmd > and then in cmd please check the ip address ans default gateway of the computer just make sure that u are not getting ip address like 169.254.1.1 or 0.0.0.0 if you get this then u need to turn off your firewall and different security software on the computer .once you get the correct ip address and default gateway then try to note down the default gateway in a piece of paper and then try to type the same number is the browser once you do this it will open up the router page on the computer do the needful changes on the computer and then check are u able to connect to the computer if not please contact me on my email address with the preffered time to call you
my email address is ullekhtandon@gmail.com
or you can contact me on fixya
thanks
techbuddies
Jan 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Help me secure my router. D-Link wbr 1310
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Configure access list in cisco router 3600
connect with console and go to the interface.
put
access-list (any no like 101 etc) deny ip (source ip / ips) (destination)
Aug 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WBR-1310. No admin logon, only f/w upgrade page
Download firmware from site
http://www.dlink.com/products/?tab=1&pid=WBR-1310&rev=WBR-1310
DLink states the login issue has been fixed with firmware v1.04 3/28/07
Remember to get the right one for your unit model. You must connect a RJ45 cable to the router and computer you have downloaded the firmware to and remember which directory it's in. When it asks for the firmware put in the target location (c:\my documents\xxxxx) of the firmware file. Good luck.
Jul 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-link wbr-1310
i think what you need to do is to login to the router by typing in its ip address like 192.168.0.1 all you have to do is hook up your computer via ethernet cable to the router then start configuring the router. you don't have to install any drivers for routers
Dec 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
125 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
